BREMBO BRAKES
Stang555
Dalton, GA
david
2016 Ford Mustang GT
Looking for some used (that are in good condition) Brembo calipers front pair and maybe rear too. They will be going on a 2016 mustang gt. If anybody are selling any let me know. 👀👀
Vicr
Fortuna Foothills, AZ
Vic
2015 Mustang Ecoboost Premium
Shelby America goes by Shelby auctions on Ebay and you can pick up new take offs for less than $500 w/ shipping (depending on bidding) for a complete front 6 piston set. Calipers, rotors w/pads and brake lines.
EFI
Masshole central
5.Br0
There's no rear Brembo calipers for the GT, unless you do the GT350 swap.
Speaking of GT350, IMO you're better off doing those than the PP calipers. They are a bit stiffer with the GT calipers and unless you can find a takeoff PP set for $500 as Vicr mentioned, the Shelby ones are not that much more expensive than most PP takeoffs I've seen.
GT350 calipers - $500
SVE adapters - $200
Rotors - $150
Pads - $70
Lines - $80
All this is brand new, you can have the GT350 Brembo setup for $1000.
Stang555
Dalton, GA
david
SVE adapters - $200
Rotors - $150
Pads - $70
Lines - $80
SVE adapters - $200
Rotors - $150
Pads - $70
Lines - $80
SVE adapters - $200
Rotors - $150
Pads - $70
Lines - $80
where are you finding gt350 Brembo setup for $1000? Cause I can’t seem to find them ? If it’s that cheap then I’ll go in that route.
EFI
Masshole central
5.Br0
LMR has the bare calipers for $500 and the brackets to install them on the GT hub $200.
GTPP 15" rotors are $75 each from Rock Auto.
Powerstop GT350 pads are $70 from lots of vendors.
Stainless lines are $80 from lots of vendors.
I also got the Caliperfexion studs for $150 to make pad changes at the track easier, but that's not required as the LMR adapter comes with the necessary OEM hardware .
Stang555
Dalton, GA
david
Ok thank you! So what can I do for the rear ones?
EFI
Masshole central
5.Br0
If you really want to upgrade, you have to get the whole GT350 rear kit. There's no adapter that I know of to make the GT350 calipers work on the GT hub.
But IMO, there's really no need unless you're a pro driver or just want to do it for the looks.
Biggsy
MD
Warren
'17 GT PP, '10 Tundra
I remember you posting about the adapter a couple months ago. Do you feel any change in the braking compared to PP calipers? I was thinking the brake bias would be thrown off but I am not too knowledge able about that.
ihasnostang
MN
www.youtube.com
Saturn ion, 2019 201A, EB PP1, Ruby Red
got a p/n from rock auto for correct rotors?
EFI
Masshole central
5.Br0
There's a ton, just select the year, make, model and go to brakes/rotor section. There you will see a bunch that are either with or without the performance brakes/Brembo. In the description, just make sure they are 15" or 380mm.
I recently purchased the Raybestos 681954FZN for like $45 each, coated hats and vanes so even less.
And to update those who might want to do this, I found the GT350 base calipers for $350 at the dealer so again even less $$$ in the end.
