Braum seats
MyLilPony
Naw It's Stock
Prosper, TX
Kris
2015 Black GT, 18 JLUR, 15 JK
I did find the passenger airbag connector I was missing. Shoved it down into the seat when I was "creatively" removing the passenger occupancy sensor bladder, and didn't realize I did that. Just got the resistor soldered on and plugged it in today.
No airbag light or warning using 2ohm 1/2 watt Resistors.
sweet! I had an issue where the seat spring was putting too much pressure on the bladder and caused the annoying seat belt beep. Made and adjustment and all is good now... Little gremlins slowly being worked out :)
jdlufkins
2022 Mustang GT Premium
I'm on the fence about getting these. I wish there was a way to try them out in person somehow lol
Unadilla248
Pennsylvannia
7x
I ordered my Braums a few days ago and will report back when I get them Installed.
Unadilla248
Pennsylvannia
7x
If anyone decides to reuse the bolt from the belt buckle mount, you'll need to get a nut to fit it for the new brackets. The threads they go in are apart of the OEM mounts.
To clarify for anyone who hasn't looked far enough yet, you need to spend about $300 on mounting brackets and hardware along with the seats, and $50 per 1/4" riser set for each seat if you want to raise them.
I would not suggest supplementing giant bolt spacers for risers, Im not an expert, but I can assume you would want a proper cut to fit piece that disperses weight across the entire mount.
I machined a few different sets of aluminum spacers 1/4in 1/2in and 3/4in to place under the planted brackets and test out some different heights, Along with the spacers I have ordered some longer 10mm ARP bolts since the stocks will be to short.
I don't see an issue with this method since the bolts that fasten the rails onto seat and bracket to the rails are only 8mm and the main seat bracket to body bolts are 10mm.
I decided to upgrade all my seat bolts both the 8mm and 10mm to ARP's
