GT Pony
- Mar 13, 2015
- Pacific NW
- 2015 GT Premium, Black w/Saddle, 19s, NAV
When I installed the Toyota brake switch pad I did notice that the diameter of the part that goes into the hole on the brake pedal seemed a little larger. I have a spare Toyota pad and the original one I took out of my GT. I just measured the diameter of the stalk with a dial caliper and got the following:Aaaaaaaaaagggghhhhhhhhh! I took my car to Discount Tire today for new shoes and on the drive back I couldn't go over 35 (power would cut out). I had replaced the broken pad with the Toyota part awhile back but something had happened to it at DT. When I got home I found it in the floor board so I guess it fell out. I had to refresh my memory on how to contort myself to get it back in. I guess perhaps I didn't get it seated well enough the first time and something they did in the process of moving my car in and out of the bay must have made it pop out. Anyway it's firmly seated now but I am kind of worried it might do it again. Just a warning to those that used the Toyota part to be absolutely sure it's completely seated.
OEM = 0.195 inch
Toyota = 0.223 inch.
There is a slit on the stalk so when the pad is installed into the brake pedal hole it will compress and fit tight. The length from the pad to the end of the stalk flare that prevents it from coming back out is basically the same on both pads at 0.105 inch.
Yours probably wasn't full seated is my guess on why it popped out.
