Brake and Clutch Fluid
plasmid
Australia
2017 Mustang GT
Hello,
I've done a little bit of searching but can't find what I'm specifically looking for.
What is the best process to 'renew' the brake/clutch fluid on a 17 GT as part of a 2 year service?
They share the same reservoir. There is a bit of information out there for 'bleeding' but not really for just changing the fluid.
Cheers.
scollist
Victoria, Australia
Shane
2017 GT Fastback, 1965 Fastback
Generally, for changing the brake fluid you use a large syringe (available from SuperCheap) to remove the old fluid from the reservoir and replace with fresh. Then bleed the brakes (longest line first) until you see clean fluid. Keep on topping up the reservoir to ensure it doesn't run dry and introduce air into the system. Repeat on all four wheels.
I'm not sure whether having a combined brake/clutch reservoir would impact this.
steerage250
Perth
Ian
2016 GT Fastback, 1928 Model A Ford
Has anyone found a fluid that matches the WSS-M6C65-A2 spec? I gave up and used anything that said DOT4.
