Boostworks Twin 62mm installed!!
Travis@boostworks
Katy, TX
www.boostworks.com
2015 Mustang GT
Attaching the turbo to the header wasn't the hard part. You need the turbo out of the way to reach the PITA bolts in the front of the motor.
Gotta have snake arms. Lol
TooSoonJunior
Southern CT
2015 Mustang GT PP M6
So whats the answer, can attach turbos AFTER headers are put back on?
pro 5.0
Canada
2019 Mustang GT
OP I know you said you are still tweaking things but your cold side piping appears to be hanging really low, do you need to clock the compressor housing to bring the pipes up ? Your coolant line also looks very close to the waste gate could just be the angle of the pic.
16silverbullet
Olympia WA
I double wrapped the coolant line by the WG. Im still trying to find the best way to tuck those charge pipes up.
Prbarnes
2013 tuned f150 ecoboost, 2015 gt premium auto
Travis, how much do y'all charge to install this kit?
Plimmer
San Antonio, TX
Rob
2015 Mustang GT
Did you do full kit with the provided Lund Tune?
Looks great, its nice to see some positivity on the forums. Looks like you took your time and did a great job!
Are you running out of fuel at 10psi? going to e85? Whats the rough HP / airflow limit before one would need more than 1000 or 1050 injectors on corn?
I would say he's probably out of fuel at 10psi. I have a VMP BAP and 50/50 e85 with 1050x injectors and it starts to run out of fuel at 6,000 rpm with my twinturbomustang.net kit. By 7300 its at 100% injector duty cycle and lean at .88 lambda
BruceStang
Shady Shoes, TX
Bruce
2016 Mustang GT Convertible
Silerbullet16, I'm glad you finally got it installed. I watched your vid. Nice pull, what tires you running?
