Mike K.
- Jul 30, 2017
- Lakeland, FL
- Mike
- 2017 Mustang GTPP
Cool I'll give it a shot
Sounds like one of those "the customer is always right, even when they're wrong" situations.NEWS!
We halted the development process quite some time ago after realizing there is not much benefit to bracing the IRS Subframe once the other available modifications (such as the CB005) are installed, but people don't want to hear it!
MGW is easy EXCEPT for the 10mm horizontal bolt on the top of the trans. You MIGHT not have clearance to remove/re-install it because the tunnel wall is closer to the trans than the bolt is long. If you are using a lift, you can just hang on the trans to pull it down to where the tunnel is wider. If you are on jack-stands, you can't use your whole weight to pull down. I got it lowered enough with a pry-bar to remove the bolt but couldn't use the pry-bar with the MGW in place. I finally had to get a 2nd person to help pull the trans down for 15 seconds.I've got a MGW to install next. If I f that up, I'll take it in and have a shop fix both.
A stock PP GT is not set up like a 1SS. Not really an apples to apples comparison. The ss is set up like a track car from the factory, GM used spherical bearings everywhere on the rear end. IRS bushings are markedly stiffer (has about 1/2 of the IRS cradle movement as the S550). Until just this year the SS also had the advantage of magnetic struts, so you can lower rid height and pre-load the coil springs for "sport" for tracking it etc. It all adds up to a tighter handling, but harsher and more noisy car.I think then numbers have been published and seem to recall that he Alpha is stiffer. Improvements from previous chassis are apples to oranges without knowing the stiffness of the previous.
Now the CTS and Camaro are not pure alpha, they are Alpha plus. The only pure alpha (so far) is the ATS the alpha plus is not quite as good as the pure alpha in a few ways but damn close. I have first hand experience with a pure alpha because I have an M6 ATS and an M6 S550. And while not scientific, my perception of them both matches the published stiffness, i.e. the ATS feels better from a handling perspective aside from factory rubber grip. Think about the ridiculous Stallone movie Driven; I believe I could pick up the quarters better in my ATS than in my Mustang PP. Then again the pure alpha ATS has lower weight and perfect 50/50 weight distribution which the Camaros and Mustangs do not.
So the weather finally warmed up a bit here so I thought I would give the CB005 kit another try on a warmer day. What a difference 25 degrees makes! Nice long burnout and no detectable hop at all. As much as this car annoys me with all the little things, that was kind of fun!!I just got my CB005 kit installed tonight. The install was easy, everything lined right up, bolts when in good and took me about 1 1/2hrs. I could feel a difference just backing out of the driveway, felt more solid and a test drive confirmed that.
I know there are many other factors that contribute to wheel hop but this kit is suppose to help. I found the hop to be worse than before. I have the oem Pirelli Nero all season tires which others have said contribute but I tried a little burnout on the same road, same place as before the kit was installed and the hop was much worse.
The kit is probably worth keeping for the better feel and no added NVH but for me no help with the hop.
Told ya!So the weather finally warmed up a bit here so I thought I would give the CB005 kit another try on a warmer day. What a difference 25 degrees makes! Nice long burnout and no detectable hop at all. As much as this car annoys me with all the little things, that was kind of fun!!
