Stangker
Hey all,
I ordered the BMR Cradle lockout kit and IRS Subframe support braces. I figured I may as well do Vertical Links at the same time.
I'm developing this car for track use. Should I order the Poly, Delein or Spherical bush Links? The Poly is significantly cheaper than the other 2 - is it good enough or will I be comrpomised?
Also, if I go for Delrin or Spherical - is it virtually mandatory to upgrade all the other control arm bushes given the extra stress placed on them with more solid vertical links?
Thanks,
Thanks,
