Gibbo205
Hi there
So tonight I fitted, the BMR CB005 cradle lock out kit which performs several functions as one kit such as:
- Rear cradle allignment, perfectly centre's rear cradle.
- Helps stop deflection in all directions of the IRS subframe bolting to factory locations.
- Vastly reduces / eliminates wheel hop.
So a little like the differential bushes, this kit uses solid aluminum pieces to fill the voids around the rubbers on the IRS subframe/cradle to the body and then helps prevent excess movement. It is very hard for me to explain, so let this video do the talking:
[ame]
Hope that explains it better.
So what are my findings:
- There is added NVH, but it is slight and not in the form of buzzing or annoying harmonics, just a little more tyre noise I'd say that shows itself generally at motorway speeds or on rougher roads, but it is slight, so if your on the motorway turn the radio up a further notch. ;)
- The driveling thud that these cars experience when taking clutch up has gone from a thud to a light clunk which I believe others found.
Those are the slight negatives, onto the positives:
- Way more feel for the car in the rear where grip levels are, communication in the butt dyno are improved for sure inspiring a lot more confidence to really push hard.
- Wheel hope is GONE!
- More traction!
So the car has more feel, more traction and the rear-end floatyness is even less so now, of course dampers should impact the this the most, but all these rear-end modifications have all helped reduce it and the rubberized feeling in the rear is now completely gone.
Car still rides really well, but response is vastly improved, when I steer the rear end is not catching up, it is now in complete sync, like I say the rubberized feeling/sensation is now completely gone in the car. So yes there is a little more NVH but it is the welcomed variety like the 911 had, feel and communication of grip. I shall report more on tyre roar at higher speeds in more normal driving when I am not driving with radio off trying to hear the slightest of noises, so yes I have to try to hear noise. ;)
So if you too feel the rear of the car is rubberized, suffers wheel hop and deflection and well feels a bit disconnected from inputs, the BMR vertical links (Delrin/Spherical), BMR cradle lockout and Steeda differential bushing inserts make a great transformation. Even better that all these parts combined cost less than £300 !! Just to note I did one at a time and performed a test drive. BMR Vertical links added zero NVH and reduced wheel hop a little and gave extra traction on corner exit. Steeda differential bushing insert system also added no NVH and took away the rubberized feeling somewhat. The CB005 added marginal NVH (tyre noise) but eliminated all the rubberized feeling in the rear and made the car more communicative and positive feeling.
Also to note the BMR CB005 cradle lockout does the job of three Steeda seperate parts that come to more than double the price and the jury is still out on those parts, yet CB005 is proven to work and for half the price!
Really hope to get dampers and springs on later this week and anti-roll bars following week, then that is it, POWER is next and with all this grip I now have I need more power for sure!
Thanks to both BMR and Steeda, great parts!
[MENTION]BMR Suspension[/MENTION]
Just a couple of questions:
1. The driveline thud these cars suffer from changing from a thud to a slight clunk, normal?
2. A little more tyre noise, again normal?
I suspect so but just want your confirmation, I did also use energy suspension grease on everything that was contacting metal.
[ame]
- More traction!
