spiller
- Mar 23, 2017
- Adelaide, Australia
- Porsche GT3
Ok thanks for the tip. I might try and completely button up one side before starting on the other. I'llI did the right side first , undoing the bolts and lowering the cradle to fit the caps. put the bolts back in and then leaving them loose and did the left side,
no problem putting the OEM brace back on as the hole is brace is hugh.
today we loosed off all the bolts and took the 4x 13 mm bolts out from the front braces, then using a ratchet strap and pry bar moved the cradle into position
making sure the bolt went in only using hand to turn if it started to bind take it out and move the cradle around and try again.once it is in then tighten up every thing to spec as per the instructions.
hope this helps
would suggest its not a one person task if it turns to :rant:
be doing it solo so might have to empty the swear jar before beginning.
