Blower motor stopped working
syclone50
Utah
Jeremy
2015 Mustang GT
My 2015 gt's blower motor stopped working. Yesterday it worked today it doesn't.
Here is what I have tested. All fuses are good. I jumped power to the motor and it operates just fine. The AC controls show the AC is on but the blower doesn't blow....anything.
With the 2 wire harness unplugged at the blower, on the car side of the plug I have voltage with the car running but as soon as I plug it back together the voltage drops to zero and doesn't change with the AC controls?
What can I check next
ORRadtech
Atlanta, Georgia
Haven't had to delve into the S550 ac system yet but every car I've ever had has had a "blower motor resistor" or something similarly named. That has also been my most common cause of no blower.
A Google search may help you out, it's pretty much the first place I look when I have problems or questions.
Deleted member 35786
Guest
The resistor and the motor are super cheap and easy to change yourself. If you have no power going to the blower with fan switch activated then its most likely the resistor. A simple 10 min job at max.
