Big turbo setup help
Darinbranham
Ohio
Darin
2020 mustang GT
Hello, I currently have 2020 76/75 big turbo setup on E85 on 10psi. Its the MT-82d4 with 3.55s. I'm looking for input on how to make the setup better I have a wheel and tire setup so far and bmr springs. But I feel like the car isn't as efficient as it could be.
Any input?
Gear change?
Suspension upgrades?
I mostly roll race from 40-60mph
Darinbranham
Ohio
Darin
2020 mustang GT
Any input?
Gear change?
I mostly roll race.
illtal
If its a roll race, the gears are ok 3.73s would give you a bit more umph.
What kind of wheel/tire combo are you running. Is it a daily? If so R-compound would be the way to go VS a street/drag radial. I'm sure many guys will have an opinion on this.
Darinbranham
Ohio
Darin
2020 mustang GT
Why would I want a 3.73 on a boosted application
Darinbranham
Ohio
Darin
2020 mustang GT
I have a weld 17x10 with Mickey Thompson ET SS
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Any input?
Gear change?
Go to 20psi. That will increase efficiency. 76/75 on a coyote isnt a big turbo by any means.
Darinbranham
Ohio
Darin
2020 mustang GT
I wish I could 20 psi is well beyond what my current fuel system can handle 15-16psi is prob my max
Darinbranham
Ohio
Darin
2020 mustang GT
Well then you just answer your question. Upgrade your fuel system
Turning up the boost isn’t what I meant. I just meant what additional things can I do to run better at 10 psi.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Got full exhaust? If you want to stay at 10psi, as someone mentioned earlier go to 373.
cahouston
Houston
2019 Mustang GT A10 Premium
How are the MT ET SS tires hooking for you? Can you elaborate on how it seems inefficient?
Darinbranham
Ohio
Darin
2020 mustang GT
they’re good don’t last long though. Idk tbh just seems a little lazy sometimes like the car doesn’t run consistently the same
