Best ODB2 scanner for S550?
Bigred911s
Big Red
Looking for feedback form members who have used scanners to troubleshoot diagnose clear and reset codes.
Plenty online and they all claim to be the best but before I pull the trpigged on one I would appreciate some suggestions on which to go with.
Thanks
Nagare
Ft Lauderdale
2017 Lightning Blue V6
RichBrew
GA
Scott
2019 Velocity Blue EBPP
Ebm
North Carolina
Guy
'14 GT
+1 to what both of the posts say above. I have the OBDLink MX as well.
Bluetooth is desirable so you can use a smartphone, tablet, or laptop.
NoVaGT
Northern Virginia
2019 PP1 GT Kona
A tuner.
Good topic, here’s another question about the aftermarket OBD scanners for newer vehicles:
Will these also decipher other such stored codes, such as ABS fault codes?
dmann
Alabama
2018 GT PP1
I have the OBDLink LX version and it works good.
michail71
2018 GT 401a A10
I think the ngauge would make a great scanner. Even without a tune you can still do gauges, run log files and mount it permanently in the dash.
3rdRGR
Indiana
Rick
2018 Roush RS2, 2025 Acura RDX
All I want to do is have the freaking double horn honk disabled. Can I just go to my Ford Dealership and tell them to do it for less than buying a scanner?
Elp_jc
None
Buy a $15 cable, and do that, plus a lot of other FORScan changes, yourself :D. And no, I don't think a dealer would do that. And even if they did, they'd charge you way more than that cable. Or just find somebody local with FORScan to do it for you, over coffee or something.
3rdRGR
Indiana
Rick
What double horn honk? the one when you lock the doors? if so that can be turned off in the cars menu from the steering wheel. The one that honks if you walk away with it running and you have the key I think can be turned off from there as well.
Press settings button on steering wheel go to advanced> vehicle > Locks > feedback. and turn off and on horn or lights or both.
I am talking about the one where you leave the vehicle with keys in pocket w car running and shut the door. Not seeing a Feedback option, nothing on horn. Lights are in another section and only allows you to turn off the daytime running lights and how long the lights stay on after shutting the doors.
Under Locks, I have Autolock, Autounlock, Mislock, Remote Unlock which then opens All Doors or Driver's Door, then Switch Inhibit.
Under Alarm, I have Settings then All Sensors Active, or Perimeter Sensing. Also Ask on Exit.
If I'm missing something and can get rid of this thing that would be truly great...
Smyth22
Illinois
Robby
Did you ever figure this issue out?! I know EXACTLY what you are talking about! I just bought my S550 in August, so I'm new, and I can't stand the double horn honk! I haven't been able to find a 100% fix...been thinking about buying the FORscan license and trying to figure it out.
opengl
PA
2018 GT PP1 400A 6MT
It's trivial to turn off with forscan, and you don't need to buy the license either.
