BCM replacement... HELP!
Alex18737
Tempe Arizona
Alex
Ford Mustang GT 2015
Hi everyone,
so my BCM, the body control module needs to be replaced.
I have 2015 Mustang GT manual transmission
have anyone done this before?
how about the programming? anyone programme new BCM?
please help!
thank you :)
thehunterooo
2006 Corvette
What is wrong with the car exactly? My BCM was acting up for a bit.
Would have to go to the dealer I expect.
Im not sure how much of this will help your particular situation, but I posted this in another thread for another user seeking BCM info.
Here ya go, BCM that is located in front of vehicle:
There is also Body Control Module B found in the trunk:
Alex18737
Tempe Arizona
Alex
Thank you so much
Have you done it before ?
I mean the programming side ?
Thank you so much
You’re welcome!
No, no programming. Try @white15gt, he had said in other threads he has done BCM programming.
z06psi
Evans, GA.
Andrew
The pot stirrer
Hi everyone,
please help!
thank you :)
Would your car not start?
FourdBanger18
Los Angeles
Andrew
2018 Ecoboost Mustang
Thank you for this
Chappers
Sutton Coldfield, UK
Greg
Toyota Supra MkV - Tungsten Silver
Hi everyone,
please help!
thank you :)
This is really helpful
In theory to programme using forscan, save your current as built data for the BCM (Save all button), install the new BCM, programme your keys then load your saved as built onto the new BCM (Load all).
Chappers
Greg
this maybe a silly question but what does PMI process mean?
FourdBanger18
Los Angeles
Andrew
That body control module has two cables running through it. Mine only has one. Partial tail light failure with two bcm’s. Don’t want to get charged again at the dealer and not get something fixed :(
IMMRSCOOBY
California
James
2018 mustang gt
You’re welcome!
Cobra hey.. so I think I fucked up my car. I have a 2018 Mustang.. I was trying to install a passenger LCD and I had to pull a harness out and remove two pins to install the LCD harness and hook it up to the bcm now my dash won't come on push to start won't work. Car just clicks. Radio and lights work any suggestions? Would ford have to replace my entire BCM?
Ecotrippn913
Kansas City
Rob
2017 premium ecoboost convertible
Same issue did you figure it out?
Brentt
Jennings louisiana
Brent
2017 mustang gt base
Did you ever figure this out? Installed same now my car just clicks won’t start lcd screen lights up no start.
Trude1400
Germany
Rene
Mustang GT 2018 Basic PP US-Version
Hi Brentt,
Do have a similar problem. How do you solved yours?
BR
René
