J_Maher_AMG
- May 29, 2016
- Newfoundland, Canada
- Justin
- 2017 GT350R (HR057)
I tried it, the lighter ports on the GT350 are always hot so a charger will work with the car off.
As far as Battery Tender vs CTEK. I have had BT's for 12+ years. Never one problem. I also have a CTEK 3300. Both extension cables are expensive. The BT has much longer cords. You need more shorter cables if you want to use the CTEK.
The CTEK tends to get pretty warm, Not sure if that is normal or not, It also seems to have some QC issues. The case seems flimsy. It does work fine and it does do desulfination (sp?). Not sure that matters unless you run your battery dead often.
On my 16, I hardwired my CTEK to the battery and used an extension to run the cable through the grille. On my 17 GT350, The connector is routed under the spoiler so it's very cover friendly and no need to keep your window cracked or your hood up. Below are he pics from my 16. My 17 is wired the same except the connector is under the splitter.
Mike, as Stage 3 mentioned, I read before that the lighter port wasn't hot so that it wouldn't work that way. But your CTEK unit does indeed work through that port?^^ABSOLUTELY! Ctek all the way.
I have this tender, the extended cable and the lighter adapter. So easy, literally plug it in and forget it. I always check on it when I go into the garage to throw out the trash or recycled to make sure all is well. Always worked great for me.
(****Just a side note,I do have a 2013 Roush Stage 3, so I'm not sure if the lighter adapter option will work for the S550 Mustangs. I was told it wouldn't. :shrug![]()
I don't think there's any way to run the wiring from the lighter adapter to the outside of the car without either having the window cracked a little or the trunk open slightly correct?
