Base model questions
mustang5o
Middle America
2023 Oxford White Mach 1 Handling Pack
Does the Mach1 base model have a "my mode" type setting that allows you to set steering, suspension, exhaust.. to your preferred setup? Does that setup stay at startup? I know on GT's I think you had to get the premium for this option but then again the premium added the all digital gauge cluster I believe, which the M1 has standard
Does anyone know if the M1 without handling pack have different traction control tuning vs having the handling package?
I'm considering getting a base with just Recaro's since I already have a track wheel and tire setup. I could buy the rear wing, front splitter and wheel well lip, and better camber plates for like $1700. Please the base model wheels/tires would make for better street driving.
Ratical
Mid TN
Nathan
03 F-250 21 Mach 1
Yes the base will include "my mode" settings, No at startup you will be in normal mode, my mode will be the first option once setup.
The traction control, I have not heard of any difference. There is different magneride handling programming.
AvalancheSVT
houston, tx
Douglas
2022 Mustang GT PP1 6spd
pretty sure as far as running gear a base M1 is going to be the slightly better than a top tier GT.
mustang5o
mustang5o
Middle America
Thanks for that info. Sucks they won't let it startup in "my mode".
I figured there was a different Magneride tune. Based on how they had different tuning between PP1 w/Magneride and PP2 Magneride I figured the Handling Package is probably more like PP2 since they both have larger front splitters and come with the wider stickier tires. Could be different based on HP having more rear downforce. I should probably just go for HP and maybe buy a different set of wheel/tires for the street.
