BAP vs DW400
Jjmoberg
KC, MO
Jeremy
2022 Mach 1
I have had a few people tell me that at my stated goal of 700ish whp on a centri at 8.5 psi, i should be good with “just a BAP” on the stock pump. I believe that from what i have seen here and in the GM world. But i still wonder about the alternative. The cost is close, if not less for the pump, if you install yourself in the factory hat.
My question is what is more reliable long term? IE, 5 years after install is a bap more likely to take a dump and leave me running, but lean, or is a DW400 in the factory hat more likely to to leave me lean or just flat die? I feel like that pump should have enough headroom that if performance degrades over time I would still be ok. And frankly from a failure standpoint I’d rather a pump take a total dump, that a BAP die and i run lean and pop a few pistons or ventilate my block.
Cory S
Bradford, NH
Cory
2016 Mustang GT Premium
Run a BAP on a DW400…..
Stock pump can’t handle 18V forever. The DW400 can.
Jjmoberg
Jjmoberg
KC, MO
Jeremy
2022 Mach 1
Thats interesting.
But the DW400 doesnt need a BAP at my goal power level does it?
Cory S
Bradford, NH
Cory
Thats interesting.
“SHOULDN’T” no…. It’s just piece of mind once you get up there.
Jjmoberg
Jjmoberg
KC, MO
Jeremy
2022 Mach 1
Fair enough. Thanks!
Still speaks to my original question. Do BAPs fail? Frequently? Usually after how long? Do they work less hard if the pump they are feeding is up to the task solo, and therefore last longer?
Mike-S550
2018 Ford Mustang GT
In all seriousness, see what your tuner prefers/finds most reliable.
Cory S
Bradford, NH
Cory
They rarely ever fail. They do no work. They are just a step up DC/DC converter.
engineermike
La
2018 GTPP A10
If a bap fails it takes about 5 minutes to bypass it.
My issue is that most tuners do not know how to tune for a bap such that the pressure control works properly.
Jjmoberg
Jjmoberg
KC, MO
Jeremy
2022 Mach 1
I will see what Wengerd says. Above makes me want to just run the DW400 …
LOL WUT
Illinois
19 GT
For the added price of a BAP (not much) why not just run the DW400 with BAP? As stated above, it’s cheap insurance.
Cory S
Bradford, NH
Cory
Not to mention, it’s literally P+P.
Jjmoberg
Jjmoberg
KC, MO
Jeremy
2022 Mach 1
Veteran
Italy
2020 GT white
I was told at low boost either will do the job. I’m no expert but I’d guess DW400 is safer, if you had to choose just one. But there is no science I refer to. Just my 2c
Slopoke
Left Coast.
Ed
2019 Mustang GT PP1 10R80
Not to derail the thread, but do all of the boost a pumps regulate voltage upon demand of ecu?
