ATI balancer question and question about higher RPMs
Dragster
2015 GT PP
I'm planning on some additions this fall, including a GT350 manifold, supporting mods, and possibly cams. Ideally, I would like my car to be solid to 8,000 RPM, if possible. I am planning on doing oil pump gears, crankshaft sprocket, and balancer. I've been looking at the ATI balancer due mostly to positive feedback on this forum. My question is this: do I go with the part #918047 which has the steel hub, or #918047A which has the aluminum hub? My car will remain N/A, and as it does see the occasional track day, I'm concerned about high RPMs.
Also, is there anything else that would be needed to "reliably" spin to 8,000 RPM? I know peak power with the GT350 manifold is much earlier, but depending on which cams I may go with, peak power might shift a little, and I want to be as safe as possible to 8,000.
Thanks in advance for the help!
Jay-rod427
Kansas
2016 GT C/S
If shooting for 8,000 you might look into the rpm pickup ring from mmr. Means pulling the trans, but get a much cleaner reliable signal that high into the revs.
Rintegration
Tampa
16 Mustang GT
Go with the steel hub
