Anyone running a 4.09 rear gear ratio ?
MRGTX
CT
2020 Mustang GT 6spd base
Reviving this thread as it looks like there's more to be said on this topic.
I am finally getting close to the end of my break-in period on my 2020 GT 6spd and I'm starting to realize that the transmission feels great to shift (yeah, I am enjoying the feel of the MT-82. I said it! :D ) and the deeper I get into the power band of the engine, the more I love it...but as stated earlier, it looks like the new ratios steal a chunk of the fun of driving a manual performance car.
It's even worse for those of us with the 3.55 axle...and I'm starting to see this mod, at least for those of us with non-PP cars, to be a requirement for the car to fulfill its promise as a sporty/muscle car.
Here are the questions that I need to answer before I take the plunge:
1.) How much worse will the fuel economy be? Is anyone smart enough to do a back of the napkin calculation on the increased RPM and energy losses to friction? If it's significant enough, it could be a factor...especially as fuel prices will certainly go up over the period of time that many of us will own these cars as daily drivers.
2.) How would the ratio impact the longevity of the motor? Would you shorten our oil change interval? Does it notably increase the amount of heat that the cooling system has to deal with? Does this mean that non-PP owners need to budget for the PP radiator?
3.) Would Ford void your warranty for this?
4.) Most importantly, Is it worth it?? What is the new ratio like to drive? Does it measurably improve performance?
maddog1982
UK
Mustang GT (S550)
Watched this yesterday, I really wish they hadn't made this change
cib24
UK
1999 Mazda RX-7 Type RS
Negilgible. The gear ratios are still so wide you won't notice any difference at all when driving, and RPMs are only 285 RPMs higher at 70 mph compared to running the stock 3.55 ratio. See below the cruising RPMs and max speeds at 7400 RPM in each gear.
Negligible if not at all. Your oil life gauge will tell you when to change the oil if you like to use that. No extra heat, it's all fine.
No.
Obviously. Without it your 2018+ GT is slower than a 15-17 GT with less horsepower up to about 80 mph due to their better gearing.
Alfa Male
Alfa Male
Worcestershire Sauce Country
Alfa Giulia
Interesting video and makes a lot of sense. Obviously this is based on the manual GTs having a 3.73 ratio whereas we are stuck with the 3.55 which is even worse.
Sort of reconfirms my thoughts on the need to play with the gear ratios.
smoke_wagon_6g
New York
18 GT
The 6 speed D4 ratios plus 3.55 is a garbage combination, really. I'm convinced more gear is the key to having fun at legal speeds with these cars. And you don't need to immediately start to mess around underhood where so many start running into drivability issues. Though you can always still bolt on a supercharger if you want.
1. Fuel Economy. Never saw a change.
2. Durability. The engine has the same redline and powerband. You may even rev it LESS since torque will be much higher at the tire. Why would engine durability be affected?
3. Void your warranty? A Ford (or any) dealer will void whenever they can. Just keep quiet when you go in for something unrelated to gears. It's not like you'll throw a code for gears.
4. Absolutely. You can now run out 2 gears to redline and just touch 70mph. You can spin tires whenever you want insted of just during a burnout. Coming from a 3.55 I calculated that peak torque to the tires is the same as if I picked up 55 lb ft at the crank. "Downside" is that you'll be shifting more. So what?
Also with a 6 speed you need no gear adjustment in the computer. I did it anyway because I already had a ProCal from the FP tune., but I noticed no difference.
maddog1982
UK
Mustang GT (S550)
This is what's holding me off getting a facelift. I wish they had not messed with the ratios.
raptor17GT
Scotland
Mustang GT Manual 2017
yeah kinda makes you chose the A10 for the facelift versions and then paddle shift when out of the traffic.
V8 WUU
Bristol - UK
Mustang GT
Has anyone actually done this in the UK?
Was the difference immediately noticeable?
The Steeda chap mentioned they can supply for 4.09 gears (for around £600 probably a bit more now)
But what sort of fitting costs would be involved?
I think the gears are the biggest downfall of my 21 GT, so would be interested in this, but if its a big operation costing thousands.... (i have no idea what is involved, but assume its a box out and apart?)
WD Pro
United Kingdom
Lime GT
Drop the diff, rebuild (gears and rebuild kit at minimum) and on a 21 you will need a tune.
I have a set with a Torsen diff, but I think they will only go in at the end of the warranty.
WD :like:
mike3105
Cambridge, UK
2018 (pre-FL) manual GT
WD :like:
I can see your chief mechanic starting the inspection! 😼
GR11M
Herts, England
Graham
Ford Mustang GT
For £600 I'd be expecting Steeda to be installing them too. You can get the 4.09 gears supplied, taxed and delivered for about £315.
GR11M
Herts, England
Graham
Ford Mustang GT
So did anyone install the 4.09 gears and did they go for the Trac lok or Torsen ?
WD Pro
United Kingdom
Lime GT
Not yet - I'm waiting on warranty expiry due to having to mess with the tune on a 19+
I have the Torsen :Like:
WD :like:
