Anyone else with fast shifting clutch issues?
chops44
TX
2018 Fathouse 1250R....1992 Gt 39k mile garage queen
Welp I installed my steeda spring today. It feels almost like it doesn't have enough spring tension at the top compared to the stock setup, but I can get over it....I made multiple high rpm "quick" shifts and the pedal didn't stick once. Not sure how, but I sure hope this fixed the issue.......
Venandakatra
Schaumburg, IL
2017 Lightning Blue GT350
I just got my spring this weekend and will be putting it in this week. I am pretty tall and it is hard for me to get up under there and be able to maneuver so it was a bit of a challenge the first try, hah. The needle nose locking pliers that I had were too thick to grab the stock spring so I need to get a smaller set.
I also found out what that clicking was - on the side of the clutch there is the clutch switch box (at least, that's what I assume it is) that I can hear when the pedal makes contact with the little plastic arm so I don't think that is part of the issue.
TRAC WPN
Kitchener, Ontario, Canada
MY16 Gt350Track
I bought some needle nose vice grips just to find it was easiest to do it all by hand without tools, held the pedal down with one hand and compressed the spring by pressing it into the lower perch, reinstalling new spring same way
Venandakatra
Schaumburg, IL
I will try to give that a shot and see how it works out. Maybe I'll grab a mirror to put on the floor so I can kind of see what is going on. If I get under the dash my left arm can't come anywhere close to getting to the spring.
jvandy50
H3249
AR
jason
23 Bronco, 18 ZL1-1LE
i had to wedge my arm in there then end up upside down with my iphone light just tilted perfect...to the side of the gas pedal. and also had about 3 sets of needle nose/vice grips that were so close, but wouldn't work...trip to the store solved it, but so aggravating with all those tools in the garage.
Hack
Minneapolis
Mustang, Challenger
Just use your fingers to pull the old spring out and install the new one. I'm a big guy, but my hands are relatively weak. I had no problem at all using my fingers to do this job. I'm sure you will also find it easy. Pliers on the other hand, are nearly impossible to use.
chops44
TX
What he said.....push the pedal in with one hand and use your other to pull the spring assembly out. Takes little force to remove the spring and even less to install it. Takes all of 5 minutes to do.
Venandakatra
Schaumburg, IL
Well, I finally had time to do this and you were right. It is waaaaay easier to do by hand than by the instruction sheet.
It also feels 500% better and there is no more pedal delay or slap on the bottom of my foot! I just did it when I got home from Wisconsin so I haven't tried a fast shift yet but it feels DRAMATICALLY improved not only in feel but in that delay.
I am really excited to try it and probably the best $15 I have ever spent on a car. +1000 for Steeda!
Venandakatra
Schaumburg, IL
I said screw it and went for a drive. Clutch pedal feel is as dramatically improved as my first impression - it is considerably easier to modulate with grip. I can also now shift medium-fast effortlessly and the car just goes. Race-fast shifting no longer bucks and the pedal doesn't stick but the pedal still doesn't return quite as fast as my foot. I may try a run or two with no spring at all and see what that feels like at some point. Definitely not leaving it off long term though.
GT_Dave
NE Illinois
1970 Mach 1 408EFI , 2016 GT350
There is no mechanical issue with running no assist spring on the clutch pedal, it is a matter of personal preference. I have been running since January 2016 without a spring, 15,000 miles and the clutch feel and shift performance could not be any better. Some cars are left with free play at the top of the travel, which is a personal fit/feel issue, my GT350 doesn't have that problem. Your not going to hurt the clutch or develop chatter as some have indicated in the past, that is propaganda to promote having a spring in place.
Venandakatra
Schaumburg, IL
Hmm, thanks for the information. I'll give it a shot and see what it is like - I don't really like play at the top of the pedal so I'll leave the spring when not racing even if that is all it will do.
