Any ideas on AC failure rates?
MustangPhil
CA
16 GT, Magnetic, Black pack, Auto
So I bought a mustang a few weeks ago after pining over the s550 for the past two years. I bought one despite knowing about the seemingly common AC failures. I want to own this car for 10-12 years, should replacing the AC every couple years just be part of the budget for owning this vehicle? Are there any solid numbers on AC failure rates yet? It definately seems like the most common issue aside from panel alignment which while mine isn't perfect, is fine.
I don't have buyers remorse of any kind, I am just really concerned about the potential for AC failure. It seems like the people that are reporting it are experiencing multiple failures. Or a 100% failure rate over time. I'm just nervous about repairs after owning a corolla for 11 years that never saw a repair shop even once. But damn if that wasn't the most boring car ever.
Additionally are there any aftermarket parts that I could buy to increase the longevity of this seemingly guaranteed to fail part? My understanding is the system is mostly plastic, and just is junk. Are there better AC systems I could use?
fionic
spaghettios and cheerios
IL
15 GT PP
never heard of the a/c failing. mine's been fine for 2 years now.
dingobreath
Perth
Mustang GT orange
If the rates of AC failure were that high, it would have been well reported by now and ford would have addressed the problem.
I wouldn't worry unless something happens, otherwise you are being paranoid for no reason.
packerfan
va
2011 mustang gt grabber blue
if you are that concerned about it failing i would recommend you buy a ford esp plan. my compressor failed on my 11 gt and all i paid is 100 dollars for a 1500 repair.
SK GT
Houston
2015 GT(sold), 17 1LE
Mine is only blowing cold air from the passenger side. Going into dealer next week. 11k miles.
HoosierDaddy
Randy
FWIW, mine stopped blowing cold air from any vent and also the fan speed was lower than normal. I disconnected the battery for a few minutes and its been working fine since. There is so much programming in these cars just about anything short of a rod sticking thru the block makes disconnecting the battery worth a shot.
trbstang
Houston, TX
Thomas
87 5.0 LX, 16 PP GT Premium
We've had several failures in our local Houston S550 club, to the point that people are waiting weeks for replacement parts. One of the members works for Ford service, and he has replaced quite a few AC system parts. AC is not something we take lightly down here! Hopefully most of us will not have issues, but I did get a 6 yr warranty on mine so it will be covered until it is paid off.
jasonstang
Denver, CO
2017 GB GT/CS 6MT
I think sometimes the sensors in the automatic HVAC can get confused.
A reset would solve the problem.
Pao_Silverstang
Tuscumbia, Alabama
Carlo
2015 Mustang ecoboost performance package
Mine stopped blowing cold air last Monday. I will go to the dealer this Tuesday.
jasonstang
Denver, CO
2017 GB GT/CS 6MT
My 17 has kinda weak AC. Takes forever to cool down compare to my 16. I hope it's not leaking.
vernonator
Des Moines, IA
Mark
2016 Mustang GT w/PP - Race Red
Ummmm isn't that the DEFINITION of Paranoia?
Agent_S550
Legend in his own mind
South Carolina
2016 Magnetic GT PP
There's a massive issue on what I believe to be non-performance pack cars for condensers. Then a lot of ecoboost and V6 cars as of late have been needing evaporators. Still have my contacts at Ford. Definitely something to be concerned with on these cars. It may of been just a bad batch of parts used on a specific subset of cars, or perhaps an early S550 issue.
I can tell you right now there are no TSB's or SSMs that i've seen as of yet.
Pao_Silverstang
Tuscumbia, Alabama
Carlo
I got my car back. The dealer said the problem is the evaporator core. He stated that its common on the new mustang and he have done several of it already. He said the new evaporator core is an updated version.
EcoBoostang
2015 Mustang Ecoboost Premium
Same thing, passenger side was only blowing out cold, hot was blowing out the driver side. They had to replace the core and received the exact same statement.
Dirtyblueshirt
Award Winning Taste™
Anaheim, CA
Aaron
2022 Ford Ranger Lariat Tremor
See the explanation I received here. It has quite a bit of info:
http://www.mustang6g.com/forums/showthread.php?t=64509
