Where is this quote from?"Most modern consumer vehicle engines are pre-programmed with specific fuel-to-air ratios, so introducing water without re-programming the car's computer or otherwise changing these ratios will most likely provide no benefit, and may likely reduce performance or damage the engine. In addition, most modern fuel systems cannot determine that water in any form has been added, and cannot determine a new compression ratio or otherwise take advantage of lower cylinder temperatures. In most cases in pre-programmed cars, introducing water vapor via an indirect water injection method causes loss of power because the water vapor takes the place of air (and fuel in engines with either a carburetor or single point injection) that is required to complete the combustion process and produce power. Normally, only vehicles re-tuned for water injection see any benefits."
So just to make sure I understand... no tune is necessary to inject 50/50?I listen to my tuner and people with my same vehicle that use it, no one else.
I’d do 50/50, best of both, a little octane boost and a little cooling.
My tuner told me he doesn’t tune for it meaning he won’t add timing or boost because if system fails more than likely so will your motor. I live in a hot environment and in Mexico sometimes do multiple runs. There’s only so much the intercooler can do in hot environments so I’m throwing a small amount of meth and water to keep the IATs in check and add a little extra octane
That’s great! Yeah I wouldn’t want it as anything other than a charge cooler. At what mani pressure do you have it set to come on then?Depends on how much you spray. I don’t use it as a fuel or timing adder so not much is needed. It’s a snow performance Kit with a #4 225ML nozzle triggered by a Hobbs switch. IAT went from 100F at the starting line to 110F at the end of the quarter mile. Use to get to about 150 before meth.
