barron64
- Jul 25, 2018
- Auburn, AL
- 2018 Mustang GT convertible PP1, 6sp, 2006 Toyota Tundra Dbl Cab 4x4, 2009 Acura MDX, 2007 Toyota FJ Cruiser
Yep chrome had its issues...It was an advancement over cast iron but... Chrome doesn't wet with oil very well and plating chrome is not the cleanest process. Plating a cylinder is 90% preparation and 10% plating. Bare aluminum bore has to be Very clean and oil free to get proper plating adhesion. There are plenty of cleaning/prep and preplate baths that a cylinder will go through before the actual plating process starts. There is a lot of room for error in the pre treatment process. If this is not done correctly you get flaking and peeling.Chrome flaking: Vintage Moto Guzzis. Pretty common. In theory it should last forever, but something caused it to flake with terminal results. Perhaps it was moisture between the chrome and the aluminum.
Nikasil failures: Jaguar is the most infamous. https://www.popularmechanics.com/cars/a6643/top-automotive-engineering-failures-jaguar-nikasil-v8/
So no matter how good it looks on the engineering paper what really matters is when it's on the road.
We did not plate any chrome but we would repair Guzzi cylinders by stripping the chrome and re-plating with nickle silicon carbide. We had to use diamond stones on our hone to properly size the cylinder to the piston. Chrome bores do not like running chrome plated rings so iron rings worked well. With NiSiC, chrome plated rings worked very well.
