AMR 19X10's Squared
Budwise
Austin, TX
2015 GT PP
Has anyone done a test fitment with the 19X10 AMR's on the front? At $139 a piece its super tempting. I know plenty of 11-14 guys fit these on the front without issues but I don't know of anyone with a 15 yet that has tested fitment. Guys @ Vorshlag insist they'll rub but I'd like to know for sure.
Back Spacing: 7.4" (188mm)
Offset: +48mm (1.9")
Bolt Pattern: 5x4.5" (5x114.3mm)
FusionGT
Large member
South Jersey
'15 Mustang GT PP / Jeep TJ
That's the sort of look I'm going for. Trying to get away from the traditional staggered setup. These wheels are a little on the heavier side but still lighter than the PP's.
gsxr1300
MA
Jason
2023 Mach 1 2015 Mustang GT PP (Sold)
those aren't labeled as fitting the 2015s
FusionGT
Large member
South Jersey
so I'm assuming the fronts would require a spacer to fit?
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
the main issue is the inner barrel clearance
the factory 19" PP wheels have a 18" inner barrel clearance
to be safe you need minimum 17.5" inner barrel clearance for the pp calipers.
Budwise
Budwise
Austin, TX
2015 GT PP
I'm having a hell of a time finding 19X10's squared that fit the PP brakes and arent $400+ per wheel. I don't understand why its such a rarity.
gsxr1300
MA
Jason
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
The issue is the following
19" PP wheels have a 18" inner barrel clearance so you need a minimum 17.5" to clear the calipers
Cast wheels have a large inner lip that is recessed in the back of the barrel which causes this clearance issue.
Rotory Forged wheels such as HRE, Forgestar have a high disk barrel and or the lip is up towards the face of the wheel which allows for the clearance needed to clear the calipers.
Flow forging is a more expensive process hence the price jump.
But we have great pricing so if anyone wants any more info they can pm me personally as well.
sunburned
NoVa
'14 WK2
Spacers + Road Courses are not really a good idea.
Use quality spacers and proper length lugs/studs and it's fine. People use huge spacers while offroading, like over an inch thick, and the wheel/tire combos weigh over 100 lbs a piece. Much more stress than a road course.
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
Actually if the spacer is larger then 10 mm
I really recommend a adapter instead its much safer.
I have the ones for my client custom CNC by our partner company. takes 2-3 days max they put the studs in and everything and price is great also.
Thompyt
El Paso, TX
Wayne
Magnetic/Red Redline GT PP Premium
With a +48mm (1.9") offset, I am not all that sure they will fit the front.
19X10
Application. This AMR Wheel fits the rear only of all 2015 Mustangs, including the V6, EcoBoost and GT models. Stagger with 19x8.5 on the front for an aggressive muscle car stance and improved traction.
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
With a +48mm (1.9") offset, I am not all that sure they will fit.
comparing this to other 10" wheels
a ET 40 works
For instance the 20x10 + 40 Targa works on the S550
