Alignment after 1 inch drop
Milton
Toronto Canada
Sqeekywheel
2020 Gt premium PP1
Has any member been able to put their alignment specs back to factory (or acceptably close to) after a 1 inch drop using factory adjustments?
AndrewMac
Pittsburgh PA
Andrew
17 GT
Interested as well, trying to make use of the money in other areas for now instead of adjustment bits. I have found that there is some room in the rear adjustment for camber and toe, see Optimums posts in here on it and for the fronts at the very least a camber bolt is cheap and effective. But beyond that not sure on the limits or 100% on specifics.
Bluelightning
Bluelightning
North of Houston, TX
Lightning Blue 2017 GT350, 2019 F-150 4x4 Ecoboost (Daily)
Rear camber is adjustable from the factory, and has enough to get it to spec, for the front, you can just get a $30 set of camber bolts.
Milton
Milton
Toronto Canada
Sqeekywheel
2020 Gt premium PP1
Thanks, I take it the front will need adjustment then. . I prefer the camber plates but I have lowered other types of cars and not needed to correct the front camber.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
The camber gain from 1” of lowering isn’t so extreme that I’d even spend $30 for camber bolts. It may actually help the handling
Lbj
Washington court House OH
Larry
2019 mustang GT. A10 auto
That’s what I am looking at or the Ford performance street springs 1 inch drop front and back
PC_GUARD
Fl
Scott
2016 Mustang GT PP1
Street springs are the PP1 springs, FYI
Milton
Milton
Toronto Canada
Sqeekywheel
2020 Gt premium PP1
I thought the Ford performance springs were only a half inch drop.
Milton
Milton
Toronto Canada
Sqeekywheel
2020 Gt premium PP1
Daily driver no track but good to know ford has that 1.25 drop.
Cruizer
Western Ohio
David
2020 Mustang Ecoboost Premium
I recently went with the BMR Performance Lowering Springs ( 1.2" drop front and 0.5 drop rear), just had it aligned. Camber on the passenger's side is just fine. The driver's is just out of spec. I'm getting -1.6 in the front and like -2.5 in the rear. Odd it's only the driver's side that's out. Anyone know the camber specs of a 2020 Ecoboost Premium?
Milton
Milton
Toronto Canada
Sqeekywheel
2020 Gt premium PP1
Specs are on your alignment software, I guess your not doing it yourself?
