Many discussions on here regarding aftermarket CAI's (regardless of vendor, brand or type).
Let's discuss...more...
Isn't a metal CAI tube more susceptible to heat soak/saturation over a similar tube that is made of plastic/rubber components (OR even the factory air intake)?
Has anyone (consumer, vendor, manufacturer) actually documented factual air intake temp differences to compare factory air intake temps vs. any aftermarket CAI temps?
The whole idea and functionality of a CAI is that the incoming air intake temp remains cool to benefit the engine AND the air is being picked up from beyond the engine bay (or through front nose of vehicle). Using components that will trap hot air, cause heat soak or possibly dilute the cooler incoming air is defeating the purpose of a CAI if designed to work better than the engineered stock air intake system.
I don't see how having an exposed air filter (or boxed in air filter) still within the confines of the engine bay is beneficial - because it is getting heat soaked while the car is sitting at idle while in traffic or if car is susceptible to extreme warm climates.
I'd like to see real world air intake temps posted up starting with stock vs. "all others".
So a beneficial post to compare data would look like such:
Air Intake Sysyem: (stock or aftermarket brand)
Owners Location: (State)
Engine temp: (approx or exact if having temp gauge)
Outside air temp: (notate day or night)
Driving Environment: (city, highway and traffic pattern low/moderate/heavy)
Air Intake Temp:
(1) at idle
(2) while driving normal highway speeds
(3) drag racing at track (where applicable)
Air Intake Temp:
(1) at idle
