Aftermarket Transmission Cooler Installed
Side_Pce
NY
2016 GT350
Just wanted to make a quick post about my Transmission cooler install.
Parts I used:
Weldon Racing 9200 pump
OEM Cooler
OEM forward lines
Earls hardline to AN fitting
Aeroquip (2) -8AN straight push lock
Aeroquip (2) -8AN 45 push lock
Aeroquip (2) -8AN 90 push lock
Aeromotive (2) 1/2 NPT to -8AN
Aeroquip socketless AQP lines 15' (used 10')
Aeroquip line hangers
(2) hose separators
Hose mount bracket (used an L bracket, mounted under transmission using existing threaded holes.)
Painless performance Relay kit
Dorman rocket switch (LED)
Dephi weatherpack connecter (+ crimper)
Various wiring parts, tools.
Hose cutter
Bolts, nuts, washers.
Fabricated mount for the pump. (I used (2) 5"x1"x1/8" stainless plates, drilled holes and tapped threads in one side to sandwich the pump T-Clamp onto the lower engine frame, right under the front sway bar. It was the only location I could find that limited the amount of line used and still be in the location of where the forward line ends. It wasn't the first place I wanted to mount it, but I didn't have the tools to make one.)
Amsoil ATF fluid
This is about all I can think of for parts.
I made a short video here. #### ####
Tomster
Beware of idiots
Tom
Nice job! congrats!
TDC
Long Island
Used the factory lines as well; makes all the difference in routing through the engine bay. Another tech pack comes to life!
Side_Pce
Side_Pce
NY
2016 GT350
Thanks everyone. Picked up a lot of info on this forum so I'll try and share as much information as I can. I ran into a number of road blocks for sure. Tools being limited, it was a struggle to make a bracket, and put the fittings in the hose. It's doable with hand tools and a little bit of imagination.
Side_Pce
Side_Pce
NY
2016 GT350
Tracked it today. Was consistent at 190. The last session it went to 210, but I think that was because I forgot to turn it on the first lap. Was in the hight 70's. Id call that a success. Just need to change the Diff fluid now.
User5.2
Audi RS3
Awesome, another tech on the track! I definitely recommend changing the diff oil as mine looked murky and dark black after 1 autocross and 2 track sessions.
rb92gt
Ponte Vedra, FL
2016 GT350 Cooled Tech
Nice job, clean install. Do you remember what size Earl's hardline to AN fitting you used? Particularly the hardline size. Thx.
Side_Pce
Side_Pce
NY
2016 GT350
I used a 1/2" to -8an male hardline adapter.
Caballus
Europe
GT350
Parts I used:
OEM Cooler
OEM forward lines
(2) hose separators
Hose cutter
Amsoil ATF fluid
[MENTION=18362]Side_Pce[/MENTION]--a few questions for you:
- What modifications did you have to make to the OEM forward lines? How much did you cut? Do you have the part numbers for the adapters?
- Do you have the part number for the L-shaped hose bracket?
- Where did you position the relay?
Thanks much!
Side_Pce
Side_Pce
NY
2016 GT350
Thanks much!
I made cuts on the straight bits of the line with a pipe cutter, staggering the cuts so the fittings didn’t hit each other.
I don’t have the L bracket part # off hand.
The relay is tricky, but not hard to set up. You’re better off buying an all weather relay and mounting it somewhere in the enginebay. I mounted it under the pass side dash with a machine screw. Worked fine enough.
Sir_Apoc
OR
2016 GT350
Nice job!
Anyone know if the factory setup is constantly cycling transmission fluid, or if it's temp specific? I wonder if you could do away with the rocket switch if you could set up a temp switch to trigger the pump.
Side_Pce
Side_Pce
NY
2016 GT350
Nice job!
The 16' track packs and 17'-18' constantly cycle fluid in the transmission. The rear axle is temp controlled.
You can set up a temp switch to trigger the relay but I only use it if I'm tracking the car or on a hot day so I didn't feel the need to try and set that up.
Caballus
Europe
GT350
Perfect. Thanks!
