I would unplug the rear microphone above the back seat above the head liner, see how it goes after that, but you may still need resonators. You are dealing with a 4cly and they can be buzzy.I put the magnaflow street mufflers on my ecoboost mustang and also eliminated the resonator it sounds good but it vibrates when pressing the accelerator so wondering if this is normal?
Thanks
The microphone is used for the Active Noise Cancellation our cars have. Its to play the sound of the car through the speakers to make the car sound better from the inside, which explains why u only hear the sound when u accellerate. When I installed my subs, it was picking up the bass and everytime I accellerated, I heard super ear destroying bass. You just pull down the headliner from the backseat and detach it. Problem was solved.What is that microphone for and how to remove that? When you say resonator do you mean a after market one?
Sit in the back seat, just pull down on the very middle of the head liner by the third brake light you will see a small black box, you can see to the left and the right where the head liner touches the roof, a magnet on both sides, just keep gently pulling down both sides you will have full access to the mic, unplug it its easy should be a tab on the connector to push, then pull the plug out.Thank but how to detach the mic. which side of the rear has the mic
So you still have the same issue of loudness and vibration when accelerating with the GT exhaust? I am going to add a resonator over the weekend or next week and will update how it goesI went thru the exact same thing with this same exhaust. First it was really bad with a catted downpipe. Put the stock one back on and was still pretty bad, I guess what you are experiencing. I then plugged up one muffler. That worked the best and ran just as good. I then finally went and sold it. Ended up with a GT exhaust with a resonator delete. It is about 50% better. I also tried the microphone in the rear disconnected with no help at all. It didn't want to cut up the Magnaflow and put a resonator in it but that might be the best option.
No its only when i accelerate at 2k -4k rpm. i hear loud exhaust sound/vibration and it goes away after i go easy on my acceleratorDoes it vibrate all the time when accelerating ? Or at certain rpm ?
If its all the time then the exhaust may be touching the body or a suspension somewhere.
When I put my exhaust on the drivers side pipe where it goes past the rear suspension was extremely close and I tweaked it a little and gain about a 1/4 inch so check there. If its touching anywhere you will feel it
