Aftermarket Exhaust Install
Bahndvr
Roushcharged
Germany
'16 Roush Warrior Mustang
So you've bought a brand new complete exhaust system. You don't want to weld it because you might want to get up in there one day. How do you keep it from coming loose?
Soulja4187
Greenacres, FL
David
2021 Mustang GT Premium & 2025 Explorer ST
gadgtfreek
Fairhope, AL
Jason
2021 GT Premium Shadow Black 10spd Auto
My Borla came with all of those...
AZ18yote
Arizona
Bryan
Most full exhausts will have the required clamps and bolts no cutting or welding needed unless you do something custom that isn't designed to fit as is.
Bahndvr
Bahndvr
Roushcharged
Germany
Band clamps with kit don't hold. Maybe I'm the odd man out.
thelostotter
AZ
2017 GTPP
Do any full exhausts require welding everything together? My ARH kit uses slip joints for every connection and once tightened are rock solid and do not leak. I was under the impression every company did that, or used bolted flanges like Kooks or Corsa.
gadgtfreek
Fairhope, AL
Jason
How about stop throwing out generics and reference a brand? I'm on my second Borla S type, with pipe that slides inside another piece, and then ratchets down with a clamp and impact. The first was on 24 months, NO issues. The second has been on the stang for 8 months, NO issues.
The point with the better brands is not to have to weld them.
Bahndvr
Bahndvr
Roushcharged
Germany
Slip joints with band clamps are not holding even after the use of impact wrench
Jackson1320
California
Jaxson
2015 mustang gt
It will not matter if you Weld the entire exhaust together. You have the headers and other then that there are only 4 bolts holding the complete exhaust in the car and the whole thing comes right out no problem
Bahndvr
Bahndvr
Roushcharged
Germany
I guess you're right. Disconnect it from the headers and work it off the hangers
NightmareMoon
2016 Mustang GT PP w/ Voodoo
Tack weld, so its going to hold, and not hard at all to grind off later.
I had no luck with clamps at the axleback, there's just so much leverage there trying to twist it.
4V Mayhem
US
2015 Mustang GT Premium M6
Go to AutoZone or Advanced Auto or Pep Boys and buy heavy duty U-style clamps. They work very well and are much more effective than band clamps.
