Active Exhaust INOP
Breakineven
MN
Brian
16 GT Premium
Hi all,
I am looking for a little help. I had a damaged exhaust valve so I replaced it but still not working. When I hit the start button(but not starting it) the valve is working as I physically can hear it move and watch it move opening and closing. Is there something that needs to be done electrical wise as a calibration? Thanks!
Rael
Grateful Member
South California
2022 Mach 1 HP Tremec
Sometimes the wires get pinched because they are so short.
SnowFox
Mn
Grabber
2022 GT, 2017 ECOboost, Saleen S351
Did you go through the reset/calibration procedure when you installed the new valve?
I'd be more specific but need a few details. You said it's still not working, but then go on to say you can hear it working? What exactly isn't working?
allfivefifty
Jaime
2022 Mach 1 HP
Also, make sure you check the cable harness and connector. If the car's exhaust has shifted back, the harness or connector can rub against the chassis and cause a short. See the video for a full explanation.
