A10 Launch Tips?
W.O.T. Stang
Jim
2019 Mustang GT Premium PP1, 2021 Kawasaki Z900
Looking for some info on the best launch tips for the A10. I've been to the drag strip many times with a manual, but this 10 speed is a whole different animal.
Obviously i know i want to select drag mode with advancetrac/stability off.
My main questions:
1. Will i be able to brake torque the car in drag mode to help with the launch and not start doing a burnout at the light? Im sure there is a limit to the rpm when doing this. Any tips for a good rpm on the stock PP1 tires?
2. Does it make any difference if i do the run in drive or sport? Obviously i know that paddle shift (manual) is a no-no on the drag strip- as the computer can shift much faster and quicker than i can. However im not sure if there any different leaving or being in drive vs sport.
3. Is an 11 totally possible under perfect conditions on a stock '19? What is a good rear tire psi for the stock tires? Any kind of burnout really needed on them? Guessing just enough to clean the tires.
Any of course, feel free to share any tips. Im excited to see what it will do.
Mikthehun1
SJ
Mik
19 GT a10, 19 Charger Scat Pack
1. Drag mode is pretty good at just launching the car. You're better off rolling on the throttle to counter any spin.
2. Keep it in drive. Drag mode gives you the faster throttle, more aggressive shifts, timing changes, etc. Putting the shifter in "S" just risks the transmission thinking you want to shift manually. If you accidentally hit a paddle, it won't shift automatically again.
3. Absolutely, and consistently once you've got the launch down.
20-22 is a good range. The sidewalls on stock tires are too stiff/short to flex much. Run too low and you risk just shredding them. Get it low enough to see a little "mushrooming".
Dead on with the burnout. No benefit to removing thread on a street tire. Clean it up and be on your way.
NC85
CA
Missing
I watched and helped a 65-70 year old man get his loaded A10 in the 11s bone stock. Everything above mentioned is correct. However, you'll need some good air to do it. The older gentleman ran 11s in 50-60 degree weather.
Mikthehun1
SJ
Mik
I like to add a little more heat to the PS4s. Not a complete burnout but enough to get some smoke.
I ran test and tune straight off the road one night and hooked up pretty good with no burnout. After cooling down I couldn't hook the car up on the 1-2 and 2-3 shift. Found if I did a 2nd gear burnout for about 2 seconds that put enough heat back in them. The temps that night were in the low 60s.
Middle of the day with summer heat though it would be pointless.
Yeah they're glue at 80 degree. Even at lower temps they heat up fairly quick. Just sitting on open tarmac under direct sun (you know, a dragstrip) might be enough even in the 60's.
Mikthehun1
SJ
Mik
Yeah they work great with heat. On the street I use the pressure monitor to check the tire temps.
Something around a PSI per 12 degrees. So starting at 32 at 70 degrees puts me at 125 degrees at 37 psi. I always use this method to check how much traction I will have. I keep the TPMS screen up most of the time driving around.
Never thought of that, neat trick.
dn1984
SF Bay Area
2018 Mustang GT A10 Premium
for my 11.9 run on cheap sumitomos and otherwise stock i turned off advancetrac (hold toggle for 5 secs), had the car in drag mode shifter in D, brake torqued to like 1200rpm or something low like that, and as far as my tires i had the rears at 25psi and the fronts at 45psi (a lot of people forget about reducing roll resistance with the front tires)
Coyote Chase
Don
2010/2018 Mustang
I launch at 1750 RPM in 1st gear w/ trans selector in sport (do not touch the paddles or it won't shift itself) and controls in drag mode with advance trac off. Stock tires at 25 psi.
Coyote Chase
Don
2010/2018 Mustang
I have since gone with M/T street slicks on the rear @ 16psi and front runners @ 48psi... (my reaction time has been as low as .069).
jmeiers
Northern Virginia
2019 Mustang GT PP1/401A/A10
Do yourself a favor... get a drag radial and your car will run the numbers you expect., consistently.
My best 60fts have come from launching off idle. Just stomp on it but you better have a tire on back first or it will go up in smoke.
51 - American Racing Headers - 1
