A/C Vent Gauge
Blake
Calgary, Canada
Blake
2015 Mustang RR GT PP Supercharged
The two gauges on the Pp car are actually on piece.
Really?... I did not expect that. So, I would have to replace both gauges? I was thinking of putting in a PLX Gauge. 2 1/16 inch.
Sixth
A
Prius
do those panels just pop off or are there screws somewhere you need to take out first?
BULL1TT
culpeper, va
2015 mustang GT, 2001 Bullitt
How did you mount it?
As for gauge I would go with Wideband AF/R if it's boosted or oil pressure if N/A. There are some multi gauges out there that give you all kinds of digital readings to select.
I made an insert that fit where the center insert was. From memory I think it was 3" outside and a 2" hole for the gauge. It was .42" thick. Also painted the aluminum dash, the vent trim, the gauge trim, the shifter trim, the cupholders, the side vent adjusters, and the bottom of the shifter flat black while it was apart
[email protected]
waynesworld
hatrsdale ny
wayne
race red gt premium auto
hey grim does that alum trim just pry off ,are there any tricks to remove it thanks,for any reply
Grim_Reaper
Grim_Reaper
'Merica
United States
Dylon
2021 Mustang GT Premium California Special 10-spd
I am not sure man. I haven't actually removed mine and am currently deployed so I won't be able to mess with it and help you out, sorry. Hopefully the guy that has done this mod can help you out.
Chargedguard5.0
Dallas
2015 GT
Remove the smaller parts by the door and steering wheel first. I think there is 2 screws under these pieces. After that you just pry it off or pull it off.
WatchSquid
D/FW Texas
Jim
93 Reef Blue Mustang convertible
I had one of my friends put in my boost gauge last night. he said it was a pain in the ass and took him about 3 hours to do. the gauge almost fits perfect in the vent but he had to make a little bracket so it wouldn't move around. It came out really nice but once a pod is available I will definitely buy it.
Great installation. That looks really professional!!
Choking_Victim
Arizona
Justin
2018 A10 GT PP
Are there no gauge pod options available for pillar or steering column yet?
gqneon
Westfield, IN
18 GT PP / Manual
So I'm in the midst of trying to put a mechanical boost gauge into my 2015 GT with PP. I removed the 2-gauge unit and have been trying to mock up a way to mount the 2 1/16th inch autometer gauge in one of the two available small holes that are there, but I've had no luck at all. That sort of fabrication isn't my strong suit.
What did you make that black insert out of to go inside your vent ?
I'm thinking if I can find some black textured abs plastic or something like that I could try trimming and modding it to be the right size to install a gauge and backing to it.
I would prefer not to mount my gauge to the dash, a-pillar, or steering column, but I guess if there's a custom mount out there I'd sure consider it because it will likely come out cleaner than whatever I cook up. I just want a clean installed look.
BTW, where did he run the lighting power wires from on that cobalt boost gauge?
:cheers:
