Clump
- Nov 19, 2015
- Frederick, MD
- 2019 Ranger
Really nice job!
It's not. Mine has lots of flaws from the weave shifting around. Doesn't matter to me though. It's mine, and has a lot of character.Amazing work, and to me looks even nicer than my OEM carbon fiber dash
It is a little tighter fit but it will work ok. I finished mine yesterday. It took about two hours altogetherIf you'll notice carefully, the distance between the gauge and the outer vents is fairly small, and not much surface material in between. That's because the PP-Gauge trim has the outer vent holes mounted further apart by about 1/4". This means that the ventilation ducting inside the dashboard is molded differently for the PerfPack than it is for the base models. If you use the PerPack dash trim, then the vents may not be perfectly centered in the original vent ducts to provide a good seal around the edges of the foam. Is it a big deal? Probably not. However, you are probably losing a little air inside your dash as a result.
