H35
- Mar 31, 2015
- Ontario, Canada
- 2015 GT
My car does not do this.
Who tuned your car?
When you cruise in D it shifts normally?
I dont believe mine is. I had pulled fuse 62 for dyno and had "forgotten" to put it back in for a while and my still shifted awful...Are you sure this isn't the stability systems pulling power?
TSS tuned it.Who tuned your car?
TSS tuned it.
I leave it in drive wherever I go. Shifts better than stock.
Yes it's a circle D Auto with a Circle D stall.Is your car an auto?
Can you send me a video of the car cruising around in 'D'
Please and thank you
Rob
Ran my auto/hellion car.Gears are 3.55 and tires are balding NT05 R 29 inch tall so less gear than 3.55.
Running base setting boost levels(5-6 psi?) .Car gauge still only reads 1 psi but I confirmed it is definitely making boost.Lol
My 12 trapped the same when it ran 10.8 and made 620 ish.
Does not pull out of the hole hard although I am sure higher stall converter will help( not going to do it as I hated it when it was in my 12 although that has a TVS).
I now see what has been said about the slow shifts.
I would love to turn boost up before my dyno appointment this Friday but now kind of scared of the boost controller.
Chris @BBR-this is the only revision I have received after sending first set of WOT logs.Who tuned your car??
