- Banned
- #121
Wow, I would have thought more. Seems your suspension/tire situation is dialed. Very nice.
I had ET street R's and those didnt work for me, the indy500s do better for me, IDK why. Cant hook below 50 mph though still.Wow, I would have thought more. Seems your suspension/tire situation is dialed. Very nice.
I'm surprised no one makes a 2.93 or 2.73 gear for these cars yet.Switching from a 3.55 diff to 3.15 to hopefully help fight some traction issues. My new set of et street r feathered in the rear as well and don’t grab anymore.
With the 315/50/17 being a 29.5 inch tire, I believe it actually makes the ratio somewhere close to a 2.93.I'm surprised no one makes a 2.93 or 2.73 gear for these cars yet.
These make my 3.55 equal to a 3.31, so without doing the math that sounds about right.With the 315/50/17 being a 29.5 inch tire, I believe it actually makes the ratio somewhere close to a 2.93.
8' of coffee straws would leak like a sieve, and probably be at ambient. But no one uses coffee straws to feed an engine. Hell those things are horrible to drink double shots out of. (Drinking game)Frankly, I roll my eyes anytime anyone quotes a boost pressure value, it's arguably the most inaccurate measurement we discuss in the automotive enthusiast world. Tire pressure gauges are more accurate. Hell, fuel level gauges are more accurate. If you put 8' of coffee straw between the vacuum/boost source and the gauge, it'll tell you it's running at ambient pressure.
Wrong. You're still filling that 8' coffee straw with pressure, once the volume fills. Engine won't consume anymore than it can.....The gauge will read exactly the same.If you put 8' of coffee straw between the vacuum/boost source and the gauge, it'll tell you it's running at ambient pressure.
Keep IAT's reasonable and there should be no problem. May not be good to do long pulls if your car is heat soaked from idling in traffic in the summer though. Also need to use good fuel. I do a run then I have to cross the bridge in the opposite direction so that gives some time to cool down but I dont think my car even needs it.I am highly impressed and jealous about the times you are putting down. My best 100-200 km/h (62-124 mph) is a 6,3 seconds with a 2016 AT, Edelbrock Stage 1, 3.25" pulley with 715 crank HP. But I am always on the edge traction and 100-200 is not my primary goal. I mostly drive on curvey country roads, but still still admire your 5,X and 4,X times.
How many pulls in a row can you do without risking the rings to blow your pistons? Or do you you all have forged internals.
There's some competing interests at play here.Keep IAT's reasonable and there should be no problem. May not be good to do long pulls if your car is heat soaked from idling in traffic in the summer though. Also need to use good fuel. I do a run then I have to cross the bridge in the opposite direction so that gives some time to cool down but I dont think my car even needs it.
My motor is bone stock , no OPGs or anything.
