4.11 gears for Ecoboost!
Scootsmcgreggor
CA
2016 Ecoboost turned GT
Must be awesome around town and getting on the freeway with that combo!
JTMtang
Massachusetts
Jonathan
2017 mustang ecoboost
So far I am definitely enjoying it. 6th gear is 2900 rpms at 80mph... So Highway travel is not bad . I think I'm going to be very happy.
Radiation Joe
Allentown, PA
2017 EcoBoost PP Manual Recaro
I was just in my spreadsheet for gearing with different rear ends and transmissions. Here are some charts of the Ecoboost with 4.09 and 3.55 rear gears. I don't like to run the ecoboost below 2000 rpm. The 4.09 gear set makes sixth gear much more usable.
4.09
3.55
AvalancheSVT
houston, tx
Douglas
2022 Mustang GT PP1 6spd
this would actually be better for the high revving v8 motors. ecobeasts just add boost.
TeeLew
So Cal
Tim
Does it or does it just ruin first gear? I have a 3.55 and I already consider second gear at parking lot speeds. When I'm driving normally, there are 5 gears (4 shifts) between stopped and 50 mph. The gearing is not too tall, you're in the wrong gear. If you want to run 3000 revs at 80 mph, then keep it in a lower gear (5th).
On a racetrack, you'd only use second to fifth. Sixth is artificially tall for fuel economy. Let the engine tick along less than 2000 rpm all day long, just don't go past 1/2 throttle at those revs. You won't need to if it's just freeway.
I think the gears are a bigger gain on the Coyote than on the Eco.
