pinero61
Boost isn't the issue... I hold 20-22 PSI with a steady drop past 4500 all the way to redline, CFM is the issue. The turbos are too small to feed the air required to push the 3.5 at speed. It's like trying to blow up a balloon quickly through a coffee stirring straw.The F-150/SHO, etc EcoBoost engine's turbos are boost controlled by the PCM. There is a misconception that if the boost drops off in EcoBoost applications its because the turbos are finished. That is not totally true. The boost does drop but that's primarily because of PCM boost management. We've seen with tuning these little turbos making boost up to 15-18PSI out close to 6000 RPM.
We've tested the stock wastegates on the EcoBoost turbos and they are fully open at 10PSI. Using these turbos on a 3.7 application without PCM boost management, means that with a simple manual boost controller, boost from 10-15PSI is easily attainable with the turbos still pumping at close to 6000RPM.
Yes bigger turbos will make more power, but these turbos are very inexpensive, make terrific street/strip power and a full system will prolly come in around $2500 or so.
I'm not saying that they won't run great on the 3.7, just that your power will be more concentrated in the low end and slowly taper off up top. My point is that you 2,500 dollar kit with a 2k dollar set of aftermarket EB turbos will be a better option than OE Borg Warners.
