2020 GT500's Scheduled For Production - Part 1
Snoopy49
Snoopy49
Posts
3,295
California
Earl
2013 GT500 and 2020 GT500
Ron, did you also have the heater hose problem?
Advertisement
RapidResponder
Posts
256
Seattle, WA
www.supermotors.net
Ron
2020 Shelby GT500, 2019 Harley Davidson F150
Not at all. Hose is laying perfectly in the cradle and angles down properly at the firewall. Found no marks on the paddle shifter either. And I had the Oil Mist Separator installed along with the Splitter Wickers, topping it off with an oil change.
All is good in the RapidResponder World!
Jmeo
You said member ;)
Posts
6,463
Massachusetts
Jaime
2020 GT500
Ron: Your hub looked about the same as mine, rust-wise. Clearly our girls sat out which kinda pisses me off. Damn glad the tires were OK.
Kent, that may look like that again already. All my past cars had that, this one too. It comes back unless you paint the exposed steel.
kilobravo
Posts
5,545
Corpus Christi Texas
www.kilobravo.com
KB
2020 GT-500
I had a feeling that would be the case, Jaime and living in South Texas, you KNOW rust is just around the bend in this constantly high humididity. :-)
I did hit the area hard with a drill-powered wire brush, Jaime then gave it a coat of primer. But, I haven't had the rears off yet so will have to do those from scratch.
On a totally different subject...
My rock guards didn't wind up being perfectly flush against the splitter and I'm still getting occasional rocks. Obviously, I didn't hold it in place well enough when marking for the top mount.
I'm gonna try a heat gun to see if I can warp them enough to be flush then hit 'em with some ice water. If that doesn't work, I'll have to re-do both top mounts.
It's always somethin' around here.
Jmeo
You said member ;)
Posts
6,463
Massachusetts
Jaime
2020 GT500
Well would you look at that, the first use of the sparingly few extras you have, lol.
Also, this might explain why you did not have to use the modified clip as a spacer???
Epiphany
Posts
5,535
Global
I like to disassemble things.
The hubs corrode badly, quickly. On delivery day mine were already on their way. They get really bad on the backside where you can't see. I also hit areas you can see in Ron's photos such as the front suspension rubber bushing shells and the underside of the tie rod and ball joint ends. I use cheap, small brushes from Home Depot in conjunction with POR-15's "MetalPrep."
I then spray WD40 onto a rag and rub it all over the same area.
Ron, looking at that closeup of your oil separator I can see what looks like the same oxidation issue I had on the valve covers, front accessory brackets, etc. You might want to take a close look at it now as it spreads like cancer into areas you can't get at. Aluminum mag wheel polish works well on those areas. I used it on my rotor hats too.
Pretty sad that I had to hand polish portions of my brake rotors on a brand new car.
Snoopy49
Snoopy49
Posts
3,295
California
Earl
I read somewhere that you needed to apply high temp anti-seize to the hub flange.
This was from the 2014 Mustang Service manual, but I saw a recent document that stated the same thing applied to the 2020 Mustangs. I don't know if they have upgraded the lube for the 2020.
"Apply a thin coat of the specified anti-seize lubricant to the hub flange"
Epiphany
Posts
5,535
Global
Yes, lubricatiing the hub is a good idea.
I remember getting a flat years ago on some POS winter beater I was driving. I was north of east bum**** and lucky to have a lug wrench and scissor jack. Problem was, the wheel had corroded around the hub register and fused the two together. I was on my back with the upper half of my body under the car, swinging a mini sledge (I worked in construction and had everything in my trunk) at the inside of the rim trying to drive it outward. I was swinging so hard that my legs would kick up in the air. A trucker pulled over because he saw that and thought I was being crushed by the car. I eventually got it off and once home beat the other three wheels off too in the same fashion.
Never more.
kilobravo
Posts
5,545
www.kilobravo.com
KB
2020 GT-500
Jaime: See, Wally World KNEW I'd need those brackets and Hell, I ALMOST sent the whole shebang to EARL! Fortunately for me, he declined for the moment. :-)
RapidResponder
Posts
256
Seattle, WA
www.supermotors.net
Ron
Thank you for the tip! Will give me something to do during my home quarantine... :wink:
Epiphany
Posts
5,535
Global
I'm out here working on mine now as we actually hit a high of 42° and I don't have to wear gloves.
Check your exhaust system too, all the way back to the mufflers. I wrapped a scuff pad around the tube and worked my way from one end to the other. I applied the metal prep on welds such as where the tailpipes enter the mufflers. Neutralizes the reaction going on and either eviscerates the rusty scale or darkens the welds.
Epiphany
Posts
5,535
Global
Scuff to remove surface corrosion you can't see along with any "flakes" and then wipe. Apply the metal prep as directed on the container. You are directed to rinse it off after so long but I use a spray bottle and hit it with a light mist and wipe again. After everything has dried/cured I hit with a WD40 swipe. I'll post some shots in the hood vent thread.
Advertisement
15 - Steeda - 6
Advertisement
