2020 GT500 - First Oil Change
Epiphany
Global
I like to disassemble things.
I've driven the car just once and amassed a bit over 1,000 miles when I made the jaunt from the dealer in Missouri to my home in NY. With the bellypan off the front and the car up in the air, now was the perfect time to change the oil. Today was also the warmest we've see since fall of 2019 at just over 55* too which is always a good excuse to do car stuff outside.
With almost a dozen quarts I wasn't going to screw around with a horizontal drain pan and went straight to a 5 gallon bucket under the oil drain plug. If you look close you can see the oil level above the mid point of the bucket. I had run the car for 10 minutes or so to warm the oil to get it to flow quickly to the drain/sump.
Drain bolt head size is 13mm.
Once all the oil was gone from the sump I reinstalled the drain plug and removed the oil filter canister and filter. Socket size for the canister is 27mm. The extension I show allows a free swing of the ratchet as the filter is in somewhat of a tight space.
I preferred the old style filter but with the somewhat shaky GT350 (:)) Ford went to a canister with replaceable media and I honestly like it from a service perspective.
The filter fits inside the housing and seats on a stamped and perforated register. Fully seated, it projects out as such...
The inside of the housing, showing the register where the filter slides over and seats once pushed in to a stop.
The case of oil and filter I purchased to service my GT500. Note the filter includes a pair of O-rings. They replace the existing O-rings.
However you choose to remove/install the O-rings, be sure you don't pierce or tear them. I really like the redundancy here that Ford chose to go with.
Make sure the filter you have is correct and not just by looking at the number on the box (shown above). It should have a perforated inner core that adds strength over previous versions of the filter that Ford used elsewhere.
Fake dinosaur juice with the consistency of water is just what the doctor ordered...
But first, the filter needs to go on.:)
You can do this a couple of different ways. I like to seat the filter in the engine first. It is an interference fit up inside so it'll stay there on its own.
Always a good idea to have some oil in the housing at startup. Most here will have the bellypan in place which is a bit restrictive. I did a couple of dry runs to see what the install angle needed to be and was then able to fill the housing with a bit of oil, maneuver it into place at the filter and start threading in.
Note the white witness marks I put on before removing the filter. Surprisingly, torquing the housing led me back to the original clocked position. Looks like they torqued it after all at the Niche plant.;)
All buttoned up, time to move back up top. Of note, our GT500's have what has to be the tiniest fill cap in existence.
This oil flows so well you don't have to worry about it backing up the filler neck and leaking onto the valve covers. I added 11.5 quarts. Do yourself a favor and get a funnel that matches the tiny neck at the cover.
Looks like I could have gone with a full 12 quarts but for now I'll follow the factory spec.
I then got in the car and reset the oil life back to 100%. Ford made it really simple to do. You simply hold ok once in the proper menu and it resets.
I finished by dissecting the original filter media to get an idea of what has been lurking within.
Of course I wish there was nothing in the pleats but oil. Given what I've see in other engines I've had (including my '16 GT350) I'd say this isn't bad at all.
And just a suggestion - stick with the factory filters here. I threw everything in a pile after I cut it up. This thing was really tight and harder to get apart then even the old-style metal canisters. Tolerances looked to be right on a very robust piece. I'm much more impressed after taking it apart then I was just by holding it in my hand and looking at it.
obspsd
IL
Keller
2017 Mustang GT Auto Ruby Red
Good info. Thanks for posting. Made for a good short read.
Sure isn’t much going on around here right now.
dirty-max
Previous: 2015 Black GT Fully Loaded (Sold) Now: 2020 GT500 (Current)
Thanks for posting this! Is it just me or does it seem like there's quite a bit of trash in the filter? Here's mine I just changed the oil in mine today as well.
Jmeo
You said member ;)
Massachusetts
Jaime
2020 GT500, 2022 F150 PowerBoost
Nice write up Tob, gives my mind a pre-run before I do mine. Only thing I am curious about now is just how much oil I can get in the housing cover, and be angle up inside the access cover without an Exxon oil spill.
kilobravo
Corpus Christi, TX
kilobravo.com
KB
'16 CT6, '18 SD, '20 GT 500
Jaime: I have a buddy who runs a Minute Man oil change store and I took a case of oil and filter up there to let them do the first change.
The tech showed me the small plate he removed and said it was much easier to replace the filter with that off.
And I had the same dipstick picture as Tob posted although I topped it off to an even twelve quarts.
As for adding oil to the housing, don't all you mechs smarter than me think there's more than enough lube left on the bearings and other surfaces even after you drain the system? I mean for the short period during turnover and engine start, do you really need to pre-feed it new oil? FWIW, I've never done this in Lord knows how many oil changes over forty years without any problems of which I'm aware.
Deviruchi
VA
2020 GT500 (L0646)
So that's how it's really done! Nice write up and pics.
Not looking forward to getting oil changes and other maintenance done at the local ford shop... brought mine it at 800 miles and was told "we use synthetic oil these days, we don't do them that often anymore."
I told him it's not about the oil it's about the engine shavings since it's brand new, got a shrug and "Whatever you say"
Epiphany
Epiphany
Global
I'd say one to two inches is all you can get in there (with no filter inside it) before you get to the point where you'd be pouring it back out when trying to angle it in place.
KB, with the bellypan in place, you must remove the door opening to allow access to the filter. Otherwise it simply ain't happening. Here's a shot of mine when I removed it and found an extra hood pin nut sitting on it that must have been dropped into the abyss during assembly...
And you always want a pressurized film of oil to protect the bearings and journals. You can wipe a bearing out very quickly. With an egine this powerful and expensive you should mitigate potential risk whenever possible.
kilobravo
Corpus Christi, TX
kilobravo.com
KB
Yep, that is the plate he showed me, Tob and roger on pressurized lube. Based on your recommendation, I will change my habits, thanks.
Roger on the hood pin nut. Once again, it reminds me of the Apollo 1 fire investigation.
Epiphany
Epiphany
Global
Just know that if you drop anything in there it will likely stay there until you pull the large pan off.
kilobravo
Corpus Christi, TX
kilobravo.com
KB
<smiling> You must know me, Tob!
There's STILL a quarter inch socket somewhere down in the innards of my '14 and for the life of me, I've never been able to find it. <smile> It's probably long gone by now though but yep, I'm a "dropper." :-)
Strokerswild
Shallow and Pedantic
Southern MN
Things With Wheels
That looks to be a fairly normal amount of crud for a factory built engine, BTW. Whenever I'd cut a filter apart after a new engine build I'd be amazed at the particles, but as long as they're tiny and uniform, game on.
The filter setup reminds me of those in my previous Jeeps, which I liked. I like Ford's double o-ring redundancy better.
Epiphany
Epiphany
Global
You are exactly right. I have a '14 JKUR with the 3.6L engine and the oil filter setup is near identical except it is inverted and on the top of the engine. Best part about it is the simplicity with respect to access. Really easy to change.
dirty-max
I havent cut open too many filters on brand new vehicles so I was a little surprised but that's definitely good to hear! I take it the metal splinters are from the aluminum block machining process?
