2019 A10 pp1 prem., drag mode engine shutdown on 2-3 WOT shift
Lo Pony
W. VA.
Take me home
86 GT, red; 88 LX 5.0, black; 95 GT black; 99 Cobra with mods (still own); ‘16 GT, PP, manual, Ruby, drivetrain vibration!; Traded for ‘19 GT, A10, velocity blue, love it.
Has this happened to you?
Car has E85 flex tune on E85.
On 1-2 shift car spins 305/35/19 Michelins pretty hard, then just gives up on 2-3 and engine shuts down to idle. This has happened a few times, and is severe enough to bark the tires (and toss me into the seatbelt) due to sudden deceleration at the top of 2nd gear (which, among other things, AIN’T good for it).
This might go better somewhere else, but since everyone’s always trolling this thread for information I figured people will at least look at it.
Edit: stability control was firm-toggled off. Also happens when traction Ctrl. Is soft toggled off. Has also occurred in track mode. Shift points are 7500-7700 RPM in drag mode. Don’t know precisely what redline is (Livernois tune). Does not occur if throttle is lifted slightly on 2-3 shift, but if I do that it shifts too early and spoils all the fun.:wink:
Lo Pony
Lo Pony
W. VA.
Take me home
Zinc03svt
usa
stang
I would log it (if you can) and send back to Livernois. More times than not it is some limiter they are missing (forgetting to turn off).
Deleted member 33561
Guest
Are you definitely on the Flex Tune and not the Race Tune? I ask because if you happened to load the Race Tune and the E85 is not really E85 that might cause the problem. The E85 race tune is more aggressive than the Flex Tune.
Dusten
Conway, Wa
Dusten
2018 Ford Mustang, 2001 Ford Lightning, 1968 Ford Mustang
Ive had this happen stock at the track a few times. In my thread it was basically determined to be stability control
Lo Pony
Lo Pony
W. VA.
Take me home
Thank you all. I will see if it happens again and verify that I am defeating traction control. Honestly, it's scary when it happens, which makes me reluctant to even try it, but I guess there's no other way to get the data.
Yes, it's definitely the flex, and not the race tune. Tuner reads fuel as "E77".
Dusten
Conway, Wa
Dusten
Mine happened and i hit the throttle 2 or 3 times before the car responded. It was pretty scary.
Lo Pony
Lo Pony
W. VA.
Take me home
I tried it three times today back to back with stability control fully defeated. It happened the last two times out of the three.
I’ll try unplugging the stability control module under the hood. I will report back here
Zinc03svt
usa
stang
Sorry, but as stated, you will lose drag mode once you unplug it.
Lo Pony
Lo Pony
W. VA.
Take me home
Just tried it and it cut out with the module unplugged. Drag mode was engaged.
Or at least it showed on the dash as being engaged, and I could tell because the throttle response is characteristically soft at easy throttle in that mode
Advice appreciated. Will call Livernois and see what they say
Lo Pony
Lo Pony
W. VA.
Take me home
Lo Pony
Lo Pony
W. VA.
Take me home
Will do, thanks!
