2015 V6 Top Speed
FireHive
Miami
2015 V6 Mustang
Joe_Stang
Glen Burnie, Maryland
Joe
2015 Mustang Ecoboost Premium
Evil87GN
Jacksonville FL
2015 TY EB auto
Driveshaft for the S550 is completely different than the '11-'14 V6, as it now has a center support bearing vs slip joint on the earlier cars. That's also why you have a higher speed limiter than the earlier cars. The 3.7 was limited to just 112 mph previously, due to that goofy slip joint in the shaft. S550 is a true two piece shaft, just like what was used in the '11-'14 5.0. Much less prone to tortional deflection/vibration than the earlier junk shaft. Current speed limiter is based more on the tire type/performance rating than the shaft design.
oyitsagreen
Charlotte
2015 Mustang GT PP
I swear my 2011 was limited to 118 mph stock.
I did have a tune on it that removed the limiter later. Let me tell you, you did not want to go faster than 125 in that car. At that speed I could feel a strong vibration coming from under the car. Any faster and kaboom!
Sent from my RM-877_nam_att_205 using Tapatalk
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
Yes my understanding is that it is tire limited first, then cooling system limited after. I'm nearly 100% sure that the V6 shares the same cooling package as the base GT.
Bay1Stang
Magnetic '15 V6 051a
c3po
CNCforlife
MN
2014 Ford Fusion- company car
I think you are right and in my opinion 121 is to low as I have reached this quite a few times on highway races. Most other v6 cars nowadays go above this speed. But on a positive note the ecoboost has the same top speed limit so that made me feel better.
I'm pretty sure that I read in a different post that the EB PP top speed was (141 ish?) and non-PP was less.
