2015 GT Vert Stereo Upgrade
Ratpack
SC
Tim
2015 Mustang GT Convertible
I have started the stereo upgrade in my 2015 GT Vert and will chronicle it here so others may input critiques and ideas and possibly get ideas for their install.
My focus is going to be more from an SQ standpoint than just loud booming bass. This will be an ongoing project for awhile since I don't have time to devote days on top of days to do the install. I like to drive my car so I want to limit the time it is down with things tore apart. The speakers I have to install are a set of Hertz Mille Pro 3 ways for the front that will be fully active and a 12" JL audio W3 for the trunk. My car came with the 12 speaker system, I have removed the sub so I can build everything in the trunk. All cabin speakers will go in the factory location, so that everything looks stock. The rear speakers will remain, but will run off the head unit, which has already been upgraded to a Linkswell "Tesla" style. It will feed the DSP with RCA cables and completely bypass the factory amplifier.
At this point, it is still in the air as to whether I put a front sub in the passenger footwell or possibly 2 8" shallow mount subs in the rear seat footwells since no one rides back there. But that will most likely be decided after the rest is installed to see if they are needed or not. I will plan for them and run the wires while I have everything apart and then IF I add them, it is simply install them and not have to tear the carpet and trim all back out.
The photos attached represent the first month or so of work. It is slow, as I mentioned not having a lot of time to devote to it all at once and as things change when I find they don't work out. I am far from an expert and only using common shop tools.
First step was to start sound deadening the trunk where the sub and amp rack will go. There is more under the carpet as well.
Next is the amp "box" which is bolted to the spare tire mount and the sub box. The sub will be down firing and it is slightly angled towards the cabin. It will have a see through panel and LED lighting in order to see into the box.
Here is the see through panel on the box, I still have to hook up the LEDs. I plan to hook them into the trunk light so that they come on when the trunk is opened, but do not stay on the whole time. They do generate some heat and I prefer it to not be too hot inside the box. This also shows the DSP location which is now where the factory sub used to be. I have mounted it using the factory sub hardware. My goal is to make this completely removable and be able to go back to stock without a lot of work.
Here I have created the floor of the trunk and mounted the DSP (no wires attached yet), still have to run all the power wires and cables. Center section will have a viewing window in order to see the AMP's and be lit by LED's like the inside of the sub box. That is why it isn't carpeted yet, still have to cut the hole out and get the acrylic window. I also plan to have "MUSTANG" embossed in the carpet under the window.
Here I have cut cardboard templates in order to create the "Beauty Panel" that will hide everything behind it and mesh with the factory carpeting. Yes, I used a pizza box from yesterday's lunch. LOL!! Hopefully I will have that cut this evening.
That's it for now. I will continue to update the thread as I make more progress. Please feel free to post advice or thoughts, this project is ever evolving.
S550HPP
PDC
2022 HPP Vert
You don't need a new sub enclosure just do 3 layers sound deadening with heat gun and roller between layers can do one of the three internally you will end up with high density enclosure.
I also did the Hertz MP 165.3, MP70, and the tweeters that come with pro kit active on AUDISON AP 8.9 controlling Kenwood XR1001.1 mounted on a cut spare wheel well foam and worked amazing. I have the AP 8.9 for sale keeping the Kenwood to work with a new DSP in new Bronco probably connected to Audison AFC or AFM DSP amp, which happens to use the MPs in kick ( incl the 3D spacer) and 3.5 in rear pods.
Ratpack
Ratpack
SC
Tim
Got the Beauty panel cut and fitted last night. Tonight will be some router work for the openings. Then onto carpet.
exvette
Illinois
Zachary
2021 GT convertible
That's exactly the information I was looking for. Thanks. Please post pictures on the front speakers when you are done. I want to see how they integrate with the pillar and door before I make my decision. Thanks.
Ratpack
Ratpack
SC
Tim
Will do, but it may be awhile before I get to that point.
Ratpack
Ratpack
SC
Tim
I got the amp rack cover and the beauty panel cut last night as well as the trim piece. The trim piece will press into place to hide the screws that hold the beauty panel in place. My plan is to carpet and upholster tonight.
Ratpack
Ratpack
SC
Tim
Quick update of the progress from last night. Got the panels upholstered with the exception of the AMP rack window, that will be done tonight. Also did the embossing on the AMP rack cover. Now on to finishing the sub box and mounting the sub in place. Also need to start working on the AMP rack layout and get the AMP's mounted.
Ratpack
Ratpack
SC
Tim
Just a quick update. Sub box is complete with the sub mounted and LED's functioning. The AMP rack is complete and the wiring done, including switches to operate all the LED's. Photo doesn't show all the wiring, but the important stuff is there. Next up is mounting it all in the car and then for my most dreaded part, running wires.
Ratpack
Ratpack
SC
Tim
I have not, I am working my way from the trunk towards the front. I plan to start pulling wire towards the front this weekend.
TonyT930
Philadelphia, Pa.
Tony
2017 Mustang GT Convertible in Ruby Red
I have a nearly new JL Audio 12w3 4 ohm sub for sale and will give you a good deal on it if you are interested. DM me.
Ratpack
Ratpack
SC
Tim
I actually already have one but I appreciate it. What did you replace it with?
Evolvd
Instigator
Northwest Florida
Brian
2021 Shelby GT500
I have a brand new set of Sounds Good Stereo speaker adapters for the front doors if you’re interested. Comes with pigtails so you don’t have to splice the wiring.
TonyT930
Philadelphia, Pa.
Tony
JL A
JL Audio 12w6 on a 2 ohm load
