TGGT
Definitely not. Also it’s much easier to drop the sub frame. It doesn’t have to come all the way out but the rear portion does have to hang quite a bit. Also as previously mentioned you will need a engine support brace.Thanks for uploading the pics. Even in random order they're helpful.
My question on the trans would be- can you remove the trans and get the oil pan out without removing the K Member? It looks like that might work, but I'm not sure if you actually have to "drop" the oil pan vs. sliding it backwards.
