2015-2016 Tech Pack and Base GT350 Cooler Solution Discussion
Tomster
Beware of idiots
Tom
I'd like to have another tranny at that price, but at what cost (one of my brethren forced to do without)? So I guess I'm happy to see FP insisting on a VIN.
Epiphany
Global
I like to disassemble things.
As I said, this isn't a supply issue. It is an artificially imposed restriction. Furthermore, it has the potential to ensure that those that do "qualify" to purchase will pay more than what they would if this was handled like the rest of the items in the FPP catalog.
Tomster
Beware of idiots
Tom
I get it. I'm just happy to see ford making this available for those who need it.
I'd still like an extra tranny. Anybody want to pm me their VIN. :D.
Just kidding
likeaboss
likeaboss
Baltimore, MD
2020 Corvette Z51
At least there are some options now which is better than being vaporware.
Screamer
Fla
Al
2116 GT350
Curious why -6 line. The stock hard line is 1/2"od ,that is -8. I plumbed mine with all -8 starlite hose/ fittings. Smaller line/ fittings make the pump work harder.
Also a Weldon pump is no prize. It is a diaphragm type pump. A real oil pump is a motor driven gear pump like the offering from RB racing.
Paul@PKAUTODESIGN
The Wheel guy
Los Angeles, California
WWW.PKAutoDesign.com
Paul A.
2016 Shelby GT350 Tech Pack #G5531 Avalanche Grey
Curious why -6 line. The stock hard line is 1/2"od ,that is -8. I plumbed mine with all -8 starlite hose/ fittings Smaller line/ fittings make the pump work harder.
Exactly !!!
Hack
Minneapolis
Mustang, Challenger
That concerns me. If I were in business and had a transmission that I was proud of I would want to sell lots of them. My conclusion is that Ford isn't happy with the Tremec transmission. I suppose one other possibility is Ford has a better transmission in the works that will be available soon?
It would be great if Ford would give tech/base owners a low price on the transmission as a step toward helping us fix the problem without trying to make a bunch of additional money from the situation. That would be a third possible explanation why Ford would restrict the number of buyers. However, the price is actually high, so I don't see where the tech/base owners are being done any favors at all.
Maybe the Weldon pump is suggested for convenience in packaging? -6 will restrict flow compared to -8. Possibly the system with the -8 has more cooling than necessary.
SchultzLT1
Chicago
2016 GT350 AG Tech Pack
It's interesting that the flow rate of the Weldon 9200 is so low. Around 30-32gph. This is much different than the 1.5-2.1gpm that those of us who created our own solution assumed. Also, that recommended pump is $429 + $695 kit + 150? Lines and fittings + $100 new oil?. I'm fine with my <$500 solution.
Ford cost total is ~$1300 actual cost, because anybody who works on anything knows there is much more than a kit involved. Also, this is all assuming that you install yourself, so add labor if you don't.
  • Like
Reactions: Jmk
firestarter2
NYC
RR G350 Track
Im guessing they know the flow rate of the internal pump and matched it. Is the kit warrantied?
mattlqx
Driver
Mesa, AZ
'22 Mach 1, '16 F-150, '14 Fiesta ST, '14 Audi A7
Who would want it other than the 2015 - 2016 Base & Tech owners?
Yeah, I don't honestly understand this either. If the prices were below cost, I'd understand, but it certainly seems like they're making a profit on all of it at the posted prices. I'm not sure what other models would benefit from this setup without further modifications.
Optimum Performance
Gold Sponsor
Titusville, Florida
www.facebook.com
Tommy
'15 GT PP
Chris, if you look at the factory line size #6 is plenty for that pump and the factory oil cooler. The Weldon pump is a low pressure/low volume pump so smaller lines are needed make it work. The Weldon is very compact, we looked at it but it comes with a price tag.
The Mocal pump we are testing in our GT rear axle cooler kit is rated for 1-3GPM. It's also rated for 350F and weighs about 7lbs. It's overkill so it will last a longtime. The idea is to give enough time for the heat exchange to take place. At the end of the day cooling of any kind is better than zero cooling. You use a pump with higher flow capacity and larger lines Plus you run real manual trans fluid in it :thumbsup:
firestarter2
NYC
RR G350 Track
Any transmission that will hold power if cheap enough will end up in other cars it happens all the time.
