1st Oil Change / Drain Plug Options
galaxy
St Louis
Just got an email update from Fumoto that their version of a drain plug/valve replacement for the yellow cam-lock valve will be released mid September.
Rubyred17
Kentucky
2017 GT350
I don’t know about your experiences but on mine if you leave the oil fill cap installed when you release the drain plug it does not gush out as badly.
I let the oil start draining and then remove the fill cap and the oil flow increases once the cap comes off
Just my experience to prevent a mess !
lightrules
lightrules
West Coast
Yes
great tip. i removed the fill cap first and the oil came out real strong. i'll try this next time.
Rubyred17
Kentucky
2017 GT350
I should have also
Mentioned that the drain pan needs to be placed back far enough to catch the flow when it increases !
JAJ
Vancouver BC
2016 GT350 Track Pack
Interesting thing about the filler cap. It's not obvious what's happening there - the driver's side crankcase vent is an open pipe from the crankcase to the clean side of the air filter, so there's no way to create a vacuum in the crankcase. BMW's on the other hand...
lightrules
lightrules
West Coast
Yes
yeah got that email too. looking fwd to seeing the final product and pricing.
Yeah, maybe Sept 2020 at best! I called them recently and they said they have no idea when it'll be ready.
galaxy
St Louis
@UPRjoe , does the new plug work just like the Ronin? Looks very similar design-wise. Also your instruction download doesn't work at your website.
My first thought. But I’m sure there’s only so many ways you can put a spin on an oil pan drain plug!
UPRjoe
750 S. Eastcoast St, Lake Worth Fl. 33460
www.uprproducts.com
Joe
UPR 2015 Ecoboost Mustang
The UPR oil drain valve has a soft lock against the o-ring and can be opened and closed all in one unit. It simply just screws in and locks in place and all you have to do is just snug it lightly when closing it and when opening it. It installs and locks in place the same as factory. I wanted UPR to offer a simple and yet cost effective upgrade. Lightrules, PM me please.
Joe
HoosierDaddy
Randy
That's gonna be a winner, UPR.
I notice it has two green o-rings while the original (without drain) has one. Any story behind that?
lightrules
lightrules
West Coast
Yes
I've got one on the way and it's perfect timing since I'm doing my oil change within the next two weeks. I'll see if I can post some pictures and maybe a video too.
UPRjoe
www.uprproducts.com
Joe
I upgraded it to the double o-ring so it's a much cleaner and tighter fit than the OEM without being able to rock it like the
factory unit does. In my opinion it needed the revision to make it a much better part and not just following everyone else.
Joe
UPRjoe
www.uprproducts.com
Joe
Limited Time Offer: 20% OFF use coupon ( drainvalve ) with any UPR Drain Plug order.
FORD Plastic Oil Pan Fix - Repair. UPR Billet Oil Drain Plugs Replaces the Ford Plastic Yellow Drain Plug Before it Fails.
Click to View Item > UPR Easy Drain Valve
