18 GT P0304 and P0307 codes
DekiDoo
Glendale, AZ
2018 GT PP1
Had my clutch and flywheel done last week. Today, check engine flashes for 30 seconds and then goes off. Shortly after that it came on and stayed on. Pulled the codes and it showed P0304 and P0307, cylinder 4 and 7 misfire. I'm guessing something was not done right when they put the new clutch and flywheel in. I'm guessing crank sensor relearn wasn't done? I just dropped it off at the dealer. We will see what they say on Monday.
Here ya go... if there is “major” work done to the transmission OR the engine such as where in either instance the trans or engine has been removed, then the shop is supposed to follow this attached SSM 45788 - which *might* explain your misfire symptoms:
DekiDoo
DekiDoo
Glendale, AZ
2018 GT PP1
Dude that is great. I'll let them know Monday. Thank you so much
RARA762
Minot, ND
Ramon
2015 mustang gt convertible
What ended up being the problem. I’m having the exact same situation than you did. Changed clutch, flywheel and installed short shifter. Just after I left the mechanic, same codes!! Cyl 4 and 7. And the car starts misfiring from around a steady 3000-4000rpm.
Graeme
Queensland Australia
Graeme
'16 Roush R727
Hi. What was the solution here?
I have the exact same scenario and have had it back to the shop where they cleared all errors and a crank angle relearn. An hour of driving later and the problem persists!?
W.O.T. Stang
Jim
2019 Mustang GT Premium PP1 401A
You need to have a cam/crank relearn done - it can be done with a high level scan tool, or the dealer. Also, i believe most handheld tuners can do it as well.
whiteheadb
Evans Ga
Brandon
Same here, what was the outcome?
W.O.T. Stang
Jim
Biggus Dickus
San Bernardino County
G
BMW M2 Mustang GT, MME GTPE
Yeah - I think an SCT X4 can do it.
What's a little weird about your situation is that you didn't get the generic P0300 code but instead specifies 2 specific cylinders.
Good luck.
jhammy49
Spring
2015 Mustang GT PP DIB
Thank you Wise and Gental Sir! After hours of wild goose chases, you handed me the key to victory! May your roads always be empty and your gas always be 100 octane!
