15-17 Front Turn Signal Swap?
MakStang
Greece
www.cellentis.uk
Makis
A 2017 miraculous little beast
Come on guys, let it go, we are here to help each other.
MakStang
Greece
www.cellentis.uk
Makis
Is this harness required even for the proper operation of the new version of the lights?
5.0_SD
Village Idiot/Biermeister
Central Florida
Bill
17 GT Base Lightning Blue
I bought mine January this year. I have not installed them, however, I still got a hold of opt7 yesterday to get the resistor harness so that when I install I won't have to do it twice. In other words, I didn't care what version I had; I figure the resistor harness can't hurt and if this allows me to just do it once, then perfect for me.
MakStang
Greece
www.cellentis.uk
Makis
Does anyone know of the resistors are already incorporated into the latest version of their lights?
emericA243
pa
2016 Ecobeast PP
Contact the engineering team and find out. My set was purchased in march and obviously they wernt.
BlownGP
Houston/Baton Rouge
Steven
Pontiac, Ford, Dodge
Sorry guys I seem to have lost my OBD2 reader so I can't check the codes. Looking over the spreadsheet and going by memory I am pretty sure this is what I changed. I will check if I find my reader.
BCM 726-45-01: xxxx 7Fxx xxxx (Allows Forscan DRL Changes)
BCM 726-26-02: x1xx xxxx xxxx (Enables Parking Lights as DRL)
BCM 726-50-01: 10xx (Enables dedicated LED DRL lights)
To get the OPT7's to be yellow in DRL mode, set 726-50-01 to 08xx.
See lines 25 and 26 on the Forscan codes spreadsheet: https://docs.google.com/spreadsheet...SN7v6AjN_t9rWvz0npQpcBbU_u0/edit#gid=53101868
Hey Allen.
I'm RaceReds brother.
I did the changed that are called for in lines 25 and 26 on the forscan spreadsheet but the signals still acts up.
I changed the IPC line too.
Still the same.
Not sure what else to change that affects the DRLs
Thanks
ahl395
Allan
Hey Allen.
Still the same.
Thanks
Line 26 has two parts to it did you change both 726-50 and 726-26?
Also keep in mind I believe it will only work correctly with the car in D, for whatever reason I believe they stay off in park. Put in D with the parking brake on and see if it works right then. If your manual I suppose just it in gear and then check.
wcharon
PR
William
Ford Mustang GT 2019 Race Red with Package 301A
Do somebody knows if this will work o a GT 2019? I wrote them but haven't received any response from them yet.
Thanks in advance...
bee bop
Temple, GA
2002 GT Vert, 2016 GT Vert
William the turn signal are different on the 18 and up mustangs. They include the fog lights and are already led. I am not sure the connectors and mounting are the same, besides you would loose your fog lights.
wcharon
PR
William
Thanks @bee bop... You are correct. I forgot the part of the Fog lights... Was totally focused on the sequential function.
Once again, thanks for the catch...
bee bop
Temple, GA
No problem.
BlownGP
Houston/Baton Rouge
Steven
Ok Allan I missed the two part section.
I did changed everything, but still acts up.
Resistors arrived!
Do the resistors work?
ahl395
Allan
Interesting, that worked for me. :whew:
