Hey Allen.Sorry guys I seem to have lost my OBD2 reader so I can't check the codes. Looking over the spreadsheet and going by memory I am pretty sure this is what I changed. I will check if I find my reader.
BCM 726-45-01: xxxx 7Fxx xxxx (Allows Forscan DRL Changes)
BCM 726-26-02: x1xx xxxx xxxx (Enables Parking Lights as DRL)
BCM 726-50-01: 10xx (Enables dedicated LED DRL lights)
To get the OPT7's to be yellow in DRL mode, set 726-50-01 to 08xx.
See lines 25 and 26 on the Forscan codes spreadsheet: https://docs.google.com/spreadsheet...SN7v6AjN_t9rWvz0npQpcBbU_u0/edit#gid=53101868
Line 26 has two parts to it did you change both 726-50 and 726-26?Hey Allen.
I'm RaceReds brother.
I did the changed that are called for in lines 25 and 26 on the forscan spreadsheet but the signals still acts up.
I changed the IPC line too.
Still the same.
Not sure what else to change that affects the DRLs
Thanks
Thanks @bee bop... You are correct. I forgot the part of the Fog lights... Was totally focused on the sequential function.William the turn signal are different on the 18 and up mustangs. They include the fog lights and are already led. I am not sure the connectors and mounting are the same, besides you would loose your fog lights.
Ok Allan I missed the two part section.Line 26 has two parts to it did you change both 726-50 and 726-26?
Also keep in mind I believe it will only work correctly with the car in D, for whatever reason I believe they stay off in park. Put in D with the parking brake on and see if it works right then. If your manual I suppose just it in gear and then check.
Do the resistors work?Resistors arrived!
Interesting, that worked for me.Ok Allan I missed the two part section.
I did changed everything, but still acts up.
Yeah, I told to get the resistors or im going to try again when I go back up there.Interesting, that worked for me.
