10R80 skips 2nd gear in Normal Mode
yeahmar
Mission Viejo, CA
Joe
2019 Mustang GT Premium, 401A, PP1, 10r80
Does anyone notice their 10R80 equipped Mustang GT skips 2nd gear in Normal Mode. My 2019 Mustang GT with 10 speed auto when starts from a dead stop goes from 1st to 3rd, skipping the 2nd gear when the drive mode is set to Normal, it does not do that in Sport+ mode, only in Normal Mode. Is it because the software is trying to get better gas mileage in Normal Mode ?
Spork3245
2019 GT Premium PP1 w/Magneride
The 10-speed auto can (and was built to) skip gears on both upshifts and downshifts when needed. Sport/Track mode generally has it run through every gear on upshifts (but can/will still skip on downshifts AFAIK).
obgod3
N.C.
2019 GT, PP1, 401A, A10
Cant say I have noticed this, it might happen but I just haven’t noticed.
nastang87xx
San Diego, CA
2016 GT350 Track Pack
The 10 speed purposely does that. That's the main reasoning behind the 10 speed. Perfect revs for any situation and all those gears gives it that flexibility.
LFSoccer2k6
STL, MO.
Greg
2023 Mach 1 Premium Jet Gray HP
I never see 2nd and 4th unless I step as lightly as possible in the accelerator. As said above, it’s designed for this.
ChaoticFury09
Toronto Ontario
Nathan
2019 GT Premium (Automatic - Magnetic)
This is correct.
Roger Blose
Fairfield, CT
Roger
2018 Mustang GT, 1988 Mustang GT, 2009 Lincoln MKZ
If you have the standard gauge cluster you can see which gear the car is in by pulling back on the + paddle lever while driving in the normal mode...pretty cool.
brucelinc
MN
Bruce
2018 Mustang GT premium A10 (SOLD)
As others have said, it is designed that way. In normal driving under relatively easy throttle, there is no need to shuffle through all the gears as you accelerate. However, under heavy throttle even in normal drive mode, it will use all the gears. It is a pretty smart transmission.
yeahmar
Mission Viejo, CA
Joe
The thing is that the car always starts in Normal mode, then you'll have to flip the switch to Sport mode, why can't Ford make the car starts with whatever driving mode it was on the last time, instead of default to Normal mode, just saying.
brucelinc
MN
Bruce
The toggle gives you sport+. If you just want to use all gears and have it hold them longer, put the shifter in S.
yeahmar
Mission Viejo, CA
Joe
That's a good point, I forget there is a S mode on the shifter, I always put the shifter in D, duh.
Kep4
Jaeger
S. Kalifornia
'19 Mustang GT PP1
LarryB
Toronto
Larry
2020 Mustang GT
My 2020 Mustang GT does the same. Autotrans skips gears depending on how you drive (Adaptive Learning). If you pick up your new car and accelerate hard the computer will register that and will skip second. I can get mine into second if I ease off on the accelerator at a particular speed and at any time with the paddle shifter. I don't think there is anything seriously wrong with the car if it skips second like that and is just a peculiarity of the way they designed the transmission. It does seem like the transmission hesitates until skipping to third when you gently accelerate and is a minor complaint.
