10r80 early upshift 6th-7th
re-rx7
Ruck the night away
Gainesville, Tx
Brandon
Was out tonight on open road and noticed the car would shift quite early into 7th around 6500-6800rpm? Trans temp was in the low 190’s no lights or anything. Is this normal?
armykyle1 [HACKED ACCOUNT
Gulf Coast
2018 GTPP premium
Pretty much.
Try it with advanced track off.
gmupatriot
Northern VA
2018 Mustang GT (Orange Fury), 401A, A10, 3.55
Yup, it short shifts. I tried to manual shift the car and it hits a built in rev limiter in 6th gear around 6600-6800 RPM. No idea why Ford did this though because shifting into 7th kinda puts it out of the peak power.
re-rx7
re-rx7
Ruck the night away
Gainesville, Tx
Brandon
I suspect it's because the 7th is the known fail point on higher hp cars for the trans. Load? Heat?
EFI
Masshole central
5.Br0
You could also be hitting the built in governor. What size tires do you have and what rear end gearing?
Andy13186
mine did this on the stock tune too, hated it
