10HP Loss, Not compression! Real reason exposed with Dyno Proof
comptech87
comptech87
Tampa, FL
Andrew
2022 Mach 1 Eruption Green
I plan on ripping that piece out of mine this weekend!
Firsttexan
2011 GT500 '19 GT PP1 '13 GT500, 98 GT, 92 LX 5.0
Good to know.
Highvolts
Ohio
Jason
2022 Mustang GT, 1965 Mustang 289
So this is inside the intake tube near the throttle body? Despite him having a different air-filter box (Mach-1 Airbox)?
2022 Mach 1
Brentwood ca
Cameron
2022 Mach 1...2014 Mustag GT whipple supercharger
If you have a GT, open your airbox and you will be greeted by two filters. Take a look, let us know what ya see.
Highvolts
Ohio
Jason
I do have a 2022 GT. If timing works out tonight, I'll take a look!
RTFM
Atlanta, GA, USA
2022 Mach 1 premium 6MT ER
So without going into politics and rabbit holes, what is it that this addon reducing airflow accomplishes for emission control?
How does that capture carbon or accomplish any active cleanup for the environment? I am confused.
2022 Mach 1
Brentwood ca
Cameron
The HC trap catches any fuel vapor that may be coming up and out of the intake when you shut off the car. Once you start it again, those HCs are drawn ba k into the combustion chamber and are burnt off where they can now enter your cats to complete the cycle.
LikeMike
NYC
2022 Mach 1
Per driver it's a minimal inconvenience. For Ford/EPA its an entire fleet of emissions savings. If a tune isn't required, kudos to Ford for making it so easy to bypass.
Eatonian49
North Carolina
Matthew
2022 Mach 1 HP, Focus SE
Not sure if the 22 would require a retune after removing it if the ECU is expecting the lessened airflow.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
No retune required. The ECU has a lot of range.
